Old 12-19-2016, 07:36 AM
Congrats on getting it going.
Old 01-03-2017, 01:45 PM
zuren zuren is offline
Now that I've been running it for a bit after an oil change, I notice I have an oil leak from one of the valve covers. Looks like Kohler uses an o-ring that is not regarded very highly in many places I've read. I found this option that looks like it may work. I found others stating they used "Form-a-gasket".
What does everyone here do on the Command engines?
Old 01-03-2017, 02:30 PM
Just replace it with OEM. They work fine.
Old 01-03-2017, 03:48 PM
Terry C's Avatar
Terry C Terry C is offline
Don't believe everything you read. I put new Kohler ones in and have had no leaks.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 01-03-2017, 07:57 PM
Stick some new O-Rings in it and a little silicone and be happy. BTDT.
Old 01-10-2017, 02:37 PM
O-rings and new breather hose are in-hand but those will go on sometime next week.
Moving on to the PTO:
This entire time the electrical connector to the PTO has been disconnected. Today I plugged this connection in and pulled the PTO knob. The tractor instantly died and got no response from anything. I found that the 20A fuse on the right side of the engine was blown. Installed a new fuse and the tractor starts again but I'm not going to toy with the PTO until I run an ohm test on it tonight.
