Old 11-12-2010, 08:04 PM
IHinIN IHinIN is offline
I made some plugs for the quick connects to keep dirt out.
Old 11-12-2010, 08:18 PM
Top notch craftsmanship, as always, Adam!
Old 11-12-2010, 08:33 PM
Thanks Allen. Working in a tool and die shop really helps with my Cub hobby.
Old 11-12-2010, 09:00 PM
mrcubcadet's Avatar
You working in that kind of shop helps my Cub hobby too! Ha ha.....:biggrin2.gif:
-105___ Tiller
Old 11-25-2010, 01:25 PM
Yamaguy's Avatar
Yamaguy Yamaguy is offline
wow that is awsome!! If I had that setup I would make a log splitter and mount it to the three point. What other rear hydraulic attachments can you think of?
Old 11-25-2010, 08:08 PM
Thanks Yamaguy. I've thought about modifying my carrier to have hydraulic dump and possibly putting an angle cylinder on my rear grader blade. I don't burn wood so I have no use for a wood splitter.
Old 07-14-2011, 05:07 PM
becullum becullum is offline
Default Hydralics
I am really impressed with your system. It seems obvious to me after reading your thread that you are a machinist since you were able to make some of the parts needed for this project. So my question to you is would you be interested in making another set up and selling it? I would be interested if it is something you would like to do. If you are than please contact me at alaskan_extreme@hotmail.com. (I live in Nebraska not Alaska as my email may deceive). I would need a turn key system because my skills include taking it out of the box, bolting it on, and adding fluid. Thats about it. Let me know what you think.
Old 10-17-2011, 08:08 PM
LarryW's Avatar
LarryW LarryW is offline
Awesome setup! Great craftsmanship!
Cub Cadet 147 2050041u340160
Cub cadet 129 main mower
Cub Cadet 1811
Old 11-23-2012, 08:07 PM
old149 old149 is offline
Default outstanding
You just helped me with some problems I was trying to solve
outstanding job
thank you old 149
Old 12-01-2012, 11:29 PM
EarlJ's Avatar
EarlJ EarlJ is offline
One curious question I have, with the pump running opposite of the engine why not mount it on the left side? or turn it around on the right side? I only ask as I am in the process of designing my setup and fully intend to use a ps pump to run my hydros for the 126. I am planning on running steel lines on the inside of the frame with front or rear ports as well as independent controls for most of the attachments I plan to utilize..
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
