Old 11-09-2011, 09:41 PM
Chis I love your stack! Sweet bracing as well!
Old 11-10-2011, 08:58 AM
70Cub 70Cub is offline
70 Cub,
Thanks!
Your only 10 minutes from me. Stop by!
Regards,
Chris
I will definitely have to do that soon, be keepin' an eye out for a PM.
Ken
Old 11-11-2011, 05:44 PM
Is this what the "stack lovers" have been looking for??
2 dollars!!
Old 11-11-2011, 06:26 PM
Sugarmaker's Avatar
CAD plans,
Price is sure right! I would assume its mild steel. I used a similar shaped cast stainless elbow, and it was way pricier at about $45! That would make a nice clean looking steel pipe too.
Regards,
Casbohm Maple and Honey
www.mapleandhoney.com
Old 11-11-2011, 09:43 PM
They sell these black elbows at NAPA,the stack is from TSC. I used a straight piece of 1" pipe out of the block.Went together pretty easy.Since I took these pictures I have added a brace to it.Vrooom
Old 11-11-2011, 11:57 PM
I would like to see a nice smooth 45 degree elbow out of the block to put the stack a bit further back towards the air breather. Looks like I'll be making a trip to NAPA for that pipe.
Old 11-12-2011, 08:02 PM
The NAPA part # is 41231
Old 11-12-2011, 08:31 PM
Sugarmaker's Avatar
DWayne,
45 degrees out of the block will get you 90 degrees to he side of the hood.
I looked at that option and felt I was getting a little close to the carb. I choose to go about 20 degrees out of the block and the stack came out between the hood and the air cleaner. I ran the tractor for a hour or so and checked the hood decal area and it was not hot. So the idea to move it away from the hood was a good recommendation by the guys on here.
Darkminion_17,
I like the smooth bend look of that coming off the 1 inch nipple.
Was just thinking my cousin said he could make a stainless muffler. I may commission him to make one for the 147. I would just chop the stack back a bit.
Regards,
Chris
Old 11-12-2011, 08:50 PM
DWayne,
Regards,
Chris
Hmm... didn't think about it being too close. There is probably not anything available to buy with that kind of bend. Would have to see if I can get someone to make a 20 degree bend maybe. Just a thought. Thanks for the heads up.
Old 12-21-2011, 01:56 PM
72-149's Avatar
72-149 72-149 is offline
you dont want it sucking hot air ..
