Old 11-15-2017, 12:24 PM
john hall's Avatar
Originally Posted by Stephen.Mellish View Post
Try putting a ratchet strap around the center of the tread. Tighten it up and it should push the sidewalls up against the rims so that you can start to inflate them.
Thats a good idea. I've helped do that with chains and load binders on BIG tires that didn't want to seat against the rim.
Myself, I use inner tubes on anything that is not an automobile.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 11-15-2017, 12:54 PM
Lanceskene's Avatar
Lanceskene Lanceskene is offline
Originally Posted by Chad126 View Post
Got the tires on the rims after some choice words.
Can't get the dang things to seal to take air. I've contemplated using the ether and fire technique. Anyone against it? I usually try to stay away from explosive (literally) solutions, but everything I have watched on youtube and read about online appears to work great. Of course I will be safe and keep a distance. Thoughts?
I wouldnt try that with ether but Ronsonal lighter fluid works very well.
Lance / Alberta Can
IH 127 w/deck, snowblade
IH 154 Loboy(x2) w/creeper 3pt and 3160 deck
CCC 12.5 w/deck
Plus 35 or so non IH tractors
Old 11-15-2017, 12:58 PM
Chad126's Avatar
Chad126 Chad126 is offline
I tried the ratchet strap technique, but I didn't put soap or anything on the rim. I imagine that would have helped. I'll give that a try tonight prior to doing the big bang method. haha.
Old 11-15-2017, 01:00 PM
Chad126's Avatar
Thank you sir. I'll look into that if the ratchet strap with soap doesn't work tonight. My wiring harness was delivered so I MAY have a running tractor prior to going to sleep tonight. *fingers crossed*
Old 11-15-2017, 01:01 PM
Chad126's Avatar
I'm regretting not using tubes at this point.... Wish I would have.
Old 11-15-2017, 11:52 PM
Chad126's Avatar
Alright. She's running... BUT, I have to start her up with a jump starter. She runs great when on the starter, but as soon as I take the jumpers off she dies. My battery is 100% crap. BUT shouldn't it continue to run on the generator? I'm assuming I've got a bad generator. Any other possibilities?
Old 11-16-2017, 12:05 AM
johncub7172's Avatar
Lightbulb
Tec Section Library- Tractors page 4 “S/G Charge Test “ is a great place to start!
Old 11-16-2017, 12:15 AM
Talking
Old 11-16-2017, 07:45 AM
Gompers Gompers is offline
Either starter/generator or voltage regulator.
If I had to hazard a guess, it’d be voltage regulator/wiring.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240
Old 11-16-2017, 09:09 AM
If your battery is that bad, it will dead short the charging system. Replace the battery and see if it charges after that. A bad battery can cook other good components.
