Old 12-26-2017, 04:00 PM
Marko141's Avatar
Marko141 Marko141 is offline
Quick pic of my quick fix.
Cub Cadet 127, 1450, read bottom plow, blower, tiller, wheel weights, chains
Old 12-26-2017, 04:03 PM
ironman's Avatar
ironman ironman is offline
Originally Posted by Marko141 View Post
Did some snow blowing today. Got a new belt, got some missing bolts, had to make some bushings. Had to make a bracket for the lift. Worked great!
I know you still have plenty to go over but this is starting to look like a story with a happy ending. By the way, it's never too soon to start keeping an eye open for number "two".
Old 12-26-2017, 04:23 PM
Marko141's Avatar
Wel I think I may be picking up a 122 with a snow plow and 38" deck, also comes with chains here soon. But I will need a better place to keep them or find a cover. I only have a car port and that's not doing much.
Old 12-26-2017, 05:32 PM
Gompers Gompers is offline
Nice! That should work great.
Looks like that's probably a wide frame lift arm. So when you pick one of those up, you can just move the brackets back out and mount it right up.
The 38" decks aren't most folk's favorites, but they will cut grass. I like the 42" and 48" decks a bit better.
Plow blades are great!
Only thing you should keep in mind is that the 122 didn't have the quick attach fittings, so things like the snowthrower and plow blade don't necessarily swap between the 127 and 122 without a little tinkering, but they are physically very similar.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240
Old 12-26-2017, 06:25 PM
Marko141's Avatar
Probably just keep the deck and snow blade on the 122 and the tiller and blower on the 127
Old 12-26-2017, 06:35 PM
twoton twoton is offline
Looks great to me!
Old 12-26-2017, 06:37 PM
Marko141's Avatar
I like that piece I added because now if I hit something with the blower there is some give, little swivel action.
Old 12-26-2017, 07:20 PM
Does the float pin work on your lift? It’s that little button on the grip like a trigger sort of.
They are often stuck or non-functional, but that’s the purpose, particularly on blades.
Old 12-26-2017, 07:34 PM
Way to go on the extension, it will work well.
I will let you know the blower will not work on the 122.BTDT
Up to 534 and counting...
Old 12-26-2017, 09:33 PM
Marko141's Avatar
Float pin is functional, I was just making the best out of the fact I needed to make something.
That 122, if I end up getting it, will only have the plow and mower on it, but who knows I may get something different
