Old 05-05-2018, 02:50 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Thank you Sam and Travis°•○●□■♤♡◇♧☆▪¤《》¡¿
1- 1200 in pieces
1- 1864 in pieces
Old 05-05-2018, 07:34 PM
Looking good Sam. If I ever get into my 1782 I might give you a call.
Btw I thought the purpose of the fuel solenoid was to prevent backfiring on engine shutdown? I know that they all get circumsized but does anyone ever have a loud flame thrower after surgery? I know that most of us let them idle for a while before shutdown but I’m just curious.
Old 05-05-2018, 07:40 PM
If you have one that wants to diesel after you turn the key off just pull the choke.
Old 05-05-2018, 07:57 PM
What is the purpose of the screw?
I have one on a CH 18 and I am curious, does it work like the throttle stop on the k series engines ?
Up to 534 and counting...
Old 05-05-2018, 09:22 PM
Lew it prevents the throttle from going full open.
Old 05-05-2018, 10:11 PM
Rescue11's Avatar
Does that mean the engine runs higher rpm then a stock18?
1- 1200 in pieces
1- 1864 in pieces
Old 05-05-2018, 10:23 PM
Yeah Sam, is it going to blow up my engine?
Old 05-06-2018, 12:37 AM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Same RPM.. the screw just limits the opening of the throttle blade on the 18 to about 75%.. kinda like a restrictor plate.. so it was just a cheap way for Kohler to build the same engine and rate them as two different engines.. Governor must also be reset to gain full use of the extra 2 hp
Won't blow it up Lew.. just allows more air and fuel in at the time.. Won't allow any more RPM.
Jay
Proud owner of the following:
Old 05-18-2018, 09:21 AM
Got a few things done on #2 seal has been replaced, engine is back in, CV joints are cleaned and repacked, new fuel lines, tank bushings, fuel shut off valves are cleaned, tank is back in place. Now onto wiring.
Old 06-04-2018, 05:59 PM
I hope to be done with this one this week. Wiring is almost finished. Just need to redo the battery cables, hook up the fuse for the PTO and connect it to the battery then I need to put the split loom on the wire harness. Everything works as it should. Low oil press light and low fuel light work, PTO turns on and off, it's charging as it should, headlights work as you can see in the pics.
