Old 03-01-2018, 12:40 PM
Joe_K Joe_K is offline
If running with lights on, the rpm's have to be high enough to show a + on the ammeter or you will eventually deplete the battery charge.
If you are running full rpms and not showing a + charge, it needs to be investigated.
Thanks, I'll test it out.
mortten mortten is offline
Manual for KT engines:
http://ccmanuals.info/pdf/TP%202043A%20KT%20Series.pdf
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 03-01-2018, 12:48 PM
Originally Posted by mortten View Post
Thanks, I have that and printed it out, didn't see a charging system troubleshooting guide. I'll have to look through it more closely at home.
Georges tip makes perfect sense, I probably didn't have it at high enough rpm's while pushing light snow. I'll try it tonight and pay attention to the ammeter. My other machine has LED lights that are on all the time so I never had to pay attention to that.
Old 03-01-2018, 02:01 PM
Page 37
Ten characters
Doug
QA-36A
42" blade
Old 03-01-2018, 02:51 PM
You don't have to run high RPM for the charging system to keep up with the lights. Half throttle is more than enough. If it isn't keeping up, you have a problem. I have 6 incandescent lights on one of my tractors, and don't have issues.
Old 03-01-2018, 03:33 PM
I guess I have a problem. This is at full throttle with the lights on.
Old 03-01-2018, 03:37 PM
Page 37
Ten characters
Thanks, just read it.
