Old 07-24-2018, 08:48 PM
Maybe one of those brass winky dinky's will fix that for you Steve
Up to 534 and counting...
Old 07-24-2018, 09:06 PM
Dirty Steve's Avatar
You got me Lew. Winky dinky? Would that describe some type of brass bushing?
Old 07-24-2018, 09:49 PM
You got that right!
Old 08-26-2018, 04:47 PM
I finally got electric PTO clutch bearing installed, air gap set, and remounted last week. So I belted up my good Haban 325 deck and had my way with the lawn yesterday. Tractor ran well. Hydro is strong and hydraulics are stout. One fan blade is missing. I detect a vibration. Not sure if just the fan blade would do it.
The steering was atrocious. I spent a couple hours this morning replacing tie rod ends and steering cylinder Heim joints. Then both front rims got new wheel bearings. Did the left steering knuckle side last. The steering knuckle had horrible slop to it. The grease zerk would not take grease yesterday during pre flight. Found the issue. Sloppy cast iron let the top split bronze bushing wander down. I had some new bushings from Motion Industries. All is better now. Hoping to get new axle pivot bolt in after squeezing the channel this coming week along with adjusting the axle slop-stop bolts out front. If I make this too nice and I'll want to keep it....
Old 08-26-2018, 08:13 PM
Nice work Dirty man, looks like it may replace one of the others you have.
Old 08-27-2018, 06:50 AM
bugeye bugeye is offline
Nice work Steve. Makes we want the same greasable rod ends for my 1864. Did you source from McMaster? If so, would you have the part numbers?
1863, 1864, 48" and 54" mower decks, 54" snow plow, 451 snow blower, TracVac 580
Old 08-27-2018, 07:03 AM
I'm pretty sure the 1864 uses a smaller rod end than a 2182, you better check before ordering.
Old 08-27-2018, 07:41 AM
https://www.onlycubcadets.net/forum/...ad.php?t=36244
This post has info on the McMaster Carr part numbers.
As Sam Mac said, make sure of your parts before you order anything. Use the Cub Cadet parts look up for your model. The jam nuts and castle nuts for the rod ends will show you what size and thread count you need.
Old 08-27-2018, 06:31 PM
On vacation this week. Some progress was made. High pressure washed the axle. Thinking of throw a spray bomb at the axle.
Old 08-28-2018, 06:20 PM
Drive shaft serviced and a 10 blade fan with all its blades installed. The fan which came on it was lacking a few. Front axle painted and reinstalled. New pivot pin/bolt in place. The front axle snubber bolts adjusted. Replaced a transmition control rod end/ball joint thinger which was held inplace with hose clamps.
New Hydro filter on after after damaging the one on it when doing the drive shaft. (Don't ask.)
Will need to adjust the neutral on the control rods and cam plate.
Still needs a nut welded on in front of frame for attachments.
Got my brother building up some worn attachment points on the deck lift.
