Old 11-14-2018, 08:28 PM
sorner's Avatar
sorner sorner is offline
".... there is slop in the hole where the popper thing goes ..."
I love it when you get all technical with us!
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
GREEN 317 with integral sleeve hitch, front hydraulic
Old 11-15-2018, 01:52 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Originally Posted by sorner View Post
Just pulling your leg. I have no idea what that thingamajig should be called! Popper thing sounds as good as any!
It's not quite as descriptive as "the little poppet nubby thingy " that Lew calls it :-)
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 11-15-2018, 02:02 PM
sorner's Avatar
Oh. I thought I missed a post that got vaporized or something. It’s usually not a good thing to have slop in the hole of anything really.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 11-15-2018, 02:06 PM
cooperino's Avatar
I think I have heard that once before somewhere
Old 11-29-2018, 10:34 PM
sorner's Avatar
Well, I started the disassembly. Getting the steering wheel off was fun, I had to use a combination of oxygenated fire, three jaw puller, a BFH, and PB Blaster to get it loose so I can take off the dash tower to get the tunnel cover off. To recap, the tunnel cover was cut into segments I guess to allow easy access to the creeper.
I’m on the fence about whether to keep the creeper or not. A full length driveshaft looks pretty affordable and I don’t really need a creeper for anything.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 11-30-2018, 07:57 AM
jbrewer's Avatar
I'd keep the creeper for its cool factor, but that's just me.
I have an O on which I'm convinced the steering wheel is permanently fused to the column. Might I ask how you applied the red wrench ?
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 11-30-2018, 08:34 AM
sorner's Avatar
The creeper needs rebuilt. That’s all. If it was good to go I would keep it no doubt. I just don’t know if I want to put the time and money into something I don’t really need.
The trick that worked (I don’t know if my other attempts helped to loosen it) was to put a small bolt down the center of the steering shaft, and put the three jaw puller on with zip ties around it to hold it in place. Then tightened it up as tight as I could get it. I heated the steering wheel right at the shaft part and it popped loose. It scared me when it let go actually. If you have plastic down to the center of the steering wheel it might be harder. Mine didn’t. It’s all steel.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 11-30-2018, 09:06 AM
Gompers Gompers is offline
I do something similar but with a bearing service tool tightened under the steering wheel. It applies more even pressure and won't pop out like a 3 jaw will so you don't have to get out the big hose clamp or zip ties. Then just tighten it down and let it sit for a while and maybe tap on the tightening bolt every once in a while and see if you can tighten it up any more. I haven't done a ton of them, but that's gotten off every one I have done with very minimal damage.
Nice work on getting that popped loose though. One of the hardest things to get off of these things it seems.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240
Old 11-30-2018, 09:47 AM
sorner's Avatar
Is there a way to restore these? The one I took off is pretty much just the metal left, but I have another one that's in better shape, and only has some cracks. I think I saw somewhere someone used JB Weld to fill the cracks and then painted the steering wheel... or maybe that was a dream...
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 11-30-2018, 10:27 AM
Bamafan Bamafan is offline
Inactive Member
Steve you can restore a steering wheel, they make a plastic putty for that purpose, I don't remember the name but there are several you tubes that show the process. Here is a you tube that I think is pretty good.
https://www.bing.com/videos/search?q...E&&FORM=VDRVRV
[B]Larry[/B]
