Old 02-10-2019, 01:47 PM
Originally Posted by Billy-O View Post
Go back to post #11.....
Glad the blower is all done and well! Good job!
You win!
Old 02-10-2019, 04:16 PM
john hall's Avatar
Originally Posted by CC2140 View Post
Well, with the engine still in pieces. I went over every part and think I found the culprit....the flywheel. On the driveshaft there is a key slot for alignment to for the timing of the spark, well on the flywheel, the male end of the slot was stripped and flywheel was out of alignment.
So, now I am awaiting a new flywheel, and since I had the entire thing apart and this should have lots of life left, I ordered all new seals from top to bottom and a new piston ring for good measure, while I was in there.
I will report back, when I get it back together.
So did it appear the flywheel had ever been removed? The only engines I remember this being an issue on were the old Briggs, those things were bad about shearing keys, but most of the time it had to do with the last guy that worked on it not getting the nut tight enough--Think a lot of them used the ratchet for the recoil and most folks didn't have the proper tool for tightening it--smacked it with a big hammer instead.
Leave push mowers that run into obstacles out of the conversation, that's a different scenario all together.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 02-11-2019, 03:41 PM
CC2140 CC2140 is offline
I can't tell it was removed, but my best assessment is that the nut holding the flywheel on became loose over time, resulting in the flywheel key slipping. It eventually stripped the flywheel male section of the key over time, eventually throwing the timing off. I placed some titelock and used a torque wrench to get it set back home.
Old 03-04-2019, 07:36 AM
Runs like a Swiss Watch!
