#51
How is the driveshaft side of the coupler?
#52
The engine to driveshaft side? It’s shot the pin was worn a good 1/4 into it. I didn’t take a picture of that one. The shaft side of the hydro end is still good. I had to work it pretty hard to pull it off.
1872 with 50C deck 1862 with 50C deck 1641 with 48GT deck 364 snow blower IH Cub Original with deck GREEN 317 with integral sleeve hitch, front hydraulic |
#53
No the driveshaft to the coupler, there is a guide pin at the end of the shaft that that fits in the coupler, they get oblong from 40 years of use and abuse.
#54
![]() Edit: I just looked the proper part up to see a picture, and mine doesn’t look anything like it. It looks just like an 82 series one.
#55
It should look like these parts.
#56
This is what I have. I’m sure it’s not the right coupler for this tractor.
#57
There should be a number cast in it.
#58
#59
Give it a clean. The part # is there.
#60
I got it, 376222 R1, which looks like it's for a 123. I did a search and some guy called darkminion17 has one for sale on ebay, but it does not look like mine. Mine has the hole the same size all the way through, the whole shaft fits inside. There's no way wear from that little shaft locator wore that out. Maybe someone had it drilled for use on a different driveshaft, like a wideframe?
