Old 07-04-2019, 09:04 AM
twoton twoton is offline
Hey Karl, sounds like your motor mounts have collapsed and the engine has dropped down in the cradle.
You should start your own thread in the IH Cub section WITH PICTURES!
Old 07-08-2019, 12:45 PM
Karl Swingle Karl Swingle is offline
Default Karl
I’m new never did this before. Asking for some wisdom, do I need to remove the motor to get the mounts replaced? Thanks for any advice.
Old 07-08-2019, 09:44 PM
sawdustdad's Avatar
Yes. Probably should visit the tech library here on the forum and download the chassis manual for your machine. Lots of good stuff there...
Replacing the iso mounts entails removing hood, front grill assembly, choke and throttle cables, a couple wires to the starter and voltage regulator, fuel line, then 4 bolts from underneath to remove the engine. Order new iso mounts from ccspecialties.org.
Old 07-08-2019, 09:59 PM
And while your at it, do the cradle mod as well as look closely @ the threaded
Holes in the Aluminum oil pan, as most are stripped.
Somebody will chime in and lead you to the multiple good write up's here.
