Old 06-21-2019, 06:01 PM
sorner's Avatar
sorner sorner is offline
Thats troooo
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
GREEN 317 with integral sleeve hitch, front hydraulic
Old 06-22-2019, 11:58 AM
sorner's Avatar
Success! I installed the new crankcase breather assembly and it’s quiet as a mouse. Well as quiet as a mouse can be around a running KT17 series II. I don’t understand why the old one made that noise. It looks physically the same as the new one except used.
I’ll take the win though.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 06-22-2019, 03:49 PM
Thinking it was leaking just enough to produce the whistling noise you heard.
You did mention it was a reed type.
prolly if installed on a different engine, it might not whistle at all.
And if it did, it might be a different tune Ha,LOL!
Old 06-22-2019, 06:49 PM
sorner's Avatar
I could put it on the old engine and it’ll be quiet.
This engine is a little “tickey” on the one side. I can hear that now that it’s not whistling. It sounds like valves. Is that how they sound? My magnum doesn’t sound like that, it just growls. I changed the oil and it was rather thin looking and had a metallic sheen in the bowl. That concerns me a little. But no smoke from the engine, there’s a little positive pressure from the vent (rubber glove) but it takes a while to fill the glove. There’s no oil in the air breather. So hopefully it’s ok. I’ll run it and see what happens. I probably can’t damage it any worse than the last engine.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 07-04-2019, 01:59 PM
sorner's Avatar
This thing will not start now. I got spark and gas. When I pull the plugs to check them there’s a little smoke that comes out of the spark plug hole. When I turn it over with the plug out it puffs the smoke out and looks like black soot. Is that flooding? Or low compression. Or both? Maybe timing? I have the points gapped at .019. It took a lot of cranking to get it started before. After it has sat a little while though it is doing this now.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 07-18-2019, 11:07 PM
sorner's Avatar
This thread has been dormant for a while, but I figured out the issue with the hard starts. It had a bad coil. It's weird because I ohmed it out and it looked ok, but I noticed it looked like the center was moving out of the case, because there was a space in the groove between the top and the side. I'm not sure what happened to it, maybe it overheated and swelled and pushed out? I had a spare here so I put it on to try it and the engine fired right up and purred. So, now it's a good runner again.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 07-19-2019, 11:44 AM
SGragg SGragg is offline
Inactive Member
Glad to hear you got it running again. There always seems to be some "new" issue to these old machines.
Stanton
1980 IH 782, Kohler M18
IH #1 Cart, original
2015 XT2, Kawasaki 23 HP
Old 07-19-2019, 01:39 PM
MattC's Avatar
MattC MattC is offline
Very true. Keeps things interesting...
Current Fleet: 100, 126, 147, 128, 1450, 1650
