#51
#52
Thanks Roland
Jim, look at the serial tag on the engine for the spec number. Assuming the engine is the correct age for the tractor it came from the tag should look like this...
![]() '70 107 with k301 engine swap '71 106 with 38" deck '70 147R with factory replacement k321, 42" deck '61 Original with 38" timed deck '63 70 "pinkie" 1863 with 54" deck '46 Farmall H, '50 Farmall Cub 105 x2 (parts) |
#53
My best guess on your problem is compression related. Pull the plug and turn the engine over. If it spins really fast, but continues to slow or stop on the compression stroke, pull the half moon shaped cam cover and check for a broken or disconnected spring on the compression release mechanism. Let us hear what you find out. Carpetbagger
#54
![]() ![]() ![]() ![]() 1951 Farmall H; 1957 Willys CJ5; 1959 Farmall Cub; 1961 Cub Cadet Original; 1963 & 1964 Cub Cadet 100's; 1971 Cub Cadet 106 |
#55
I wish I could. Th PO had a PO had a PO, etc. The tractor was painted black & yellow when I got it if that tells you anything. As far as a SN tag and spec# - it had one, but it had been "cleaned" with sandpaper, as far as I could tell. Virtually unreadable. The closest I could make out was SN A918098, Spec 46858. I can't verify that though. Here's a picture of the blower cover with tag when I got it:
#56
#57
LOL. Yeah, with the help of a gear puller and impact wrench! No damage though...
