#651
Pulled snow duty 125 out of shed.
pulled grass duty 125 out of shed ( started right up--star tron gas treatment and a battery tender work great ) Put snow duty 125 back in shed. mowed for the first time this year Put the 125 back in the shed
#652
Ordered some parts from Jeff, got cork gaskets in the mail so reinstalled the hydro, replaced the engine side coupler, (good thing, the aluminum cup that it bolts to was shot as well) took steering column apart and cleaned all of the old grunge out/ regreased it with fresh. Hydro linkage seems to be a little loose, don't see any adjustments possible to tighten it up, will have to see once I get everything hooked back up, will fire it up on a jack to see, before I put the body back on.... hopefully if it walks down towards neutral, the linkage on the parts 129 is in better shape.... I will need to get new tie rod ends for the link from the shift rod to the shift linkage on the trans anyways.
#653
Installed tubes in the rear tires of my 125. What a job.
#654
Made the brakes work on the 126, pulled the 42" deck and cleaned it all out. Hoping to find a NF front blade for it. Seems there's 5 WF blades for every NF one. Also got the blades for my 50C razor sharp, but there's bad news on that deck.
'74 IHCC 108 - 38A, supersteer axle '75 IHCC 1000 - 44A, Sears wheel weights '87 CC 1872 and 1811 - Haban, 44C '96 CC 1863 - 54GT '79 JD 400 - 60" deck "Projects" '67 123, '65 102, '71 126 |
#655
My neighbor I sold my restored 102 to put some duals on the rear of it! Kinda jealous.
#656
I finished putting the motor back in my 129 after changing the oil pan, then put the mower deck on and took it for a short ride.
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart ![]() ![]() ![]() ![]() ![]()
#657
Nice 129!
#658
Mowed with the 782, and took 7 trailer loads of hedge/tree trimmings out into the woods to dump with the 122 mutt. Trimming and hauling took 3.5 hours .
Just noticed that the muffler was blowing out (hard to get 60 yrs out of a muffler these days) so I ordered a replacement. Did I mention it was in the lower 90's today?
#659
Mowed the lawn with the 100 and then parked it next to his older big brother
64 Cub Cadet 100 Also have quite a few Non Cub Cadets in the Shed
#660
