#61
Thanks Allen, all part of the "fun."
#62
PTO fun continues. QUESTION: Anybody know the maximum size drill bit I can use on these set screws?
I finally got all 3 sets of screws drilled through. I was lucky on one, you can see what remains of it on the paper that neatly turned itself out with the bit. The other two remain stubborn to the bitter end. The tap set is a loaner from O'Reilly Auto Parts, and the 1/4" is short enough that you can work the threads from both sides. Elephant in the room, all this is wasted effort if I can't find a shop willing to turn down the Rocky Mountain texture. I do things backwards sometimes, drives my wife over the edge. |
#63
try a trans shop, they'll have a machine that resurfaces clutch plates and flywheels
Doug Original / IH 70 / IH 149 / IH 1650 / IH 582 / CCC 1772 West Central Ohio Farmall & Cub Cadet Club https://www.facebook.com/#!/groups/226681087497199/ |
#64
Thanks bud, that really helps. I have one just up the street from the office.
#65
Mini update: 2 of 3 set screw holes are tapped through and ready to go, one was very "iffy" but I think it will work fine. One to go, slow process.
#66
Bummer.
The PTO pulley is not salvageable. After working really hard and getting 2 of the 3 set screws out and re-tapped, the 3rd one cratered on me. It's a long story, but I just did not have the right tools and enough skill to pull this one off. So, does anyone have a spare pulley I can buy? I need the type that uses the two front springs instead of the one that has the bends on the ends. I've already sunk $60 bucks into the clutch kit and want to use it. The friction plate will be fine, I need just the pulley so I don't have to lay down another $100 plus on a full PTO from ebay and the like. Anyone? |
#67
Make an add in the Wanted section for your needs.
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
#68
Update:
Intact PTO pulley coming from one of our forum members. Dash tower has been sandblasted and primed....that was a bear of a job. My blast cabinet is not large enough so I had to to an outdoor setup. Tons of nooks and crannies to have to shoot. I can't imagine trying to prep this piece by wire wheel or hand sanding. Big hurdle is done. |
#69
Looking good! Thanks for the pic and update, TSV!
#70
