#61
Great job! I agree, with Mike. Can't wait to see it on your tractor.
#62
RandyD,
Haven't seen our cat (Gracie) for a day or two. I think you have her She looks just like ours.Todd, Rattle can Rust-oleum Antique White, over Rust-oleum gray automotive primer. I am not sure I would recommend this paint, as it stays soft a long time. I did pick up the rest of the stainless hardware today. Then need to fab the handle to move the outlet hood. Mountain Heritage, Thanks for reminding me that these are supposed to go on a tractor. I may not do that this season? I have another tractor to plow with and may take this implement to some local shows next year??? We will see? Allen, Thanks. You guys and this forum have helped a bunch keeping me focused and moving on this snow thrower project! Regards, Chris
Casbohm Maple and Honey www.mapleandhoney.com Cubs: 147R and the "train", 127 elec lift, 127, 125, 106, 102, 100, 86, 73, Brinly plow, Snow thrower, 2 Rototillers, several mower decks and several snow plows, #1 cart, Grandkids barrel cart. |
#63
Awesome work Chris! Those dolly work great! Someone posted last year pics of them using four of them and putting their tractor on them to movem them around the shop!
#64
Duke,
I will keep that in mind on the dollies! Regards, Chris
#65
Had some time tonight to try to complete this "snow thrower" project.
I built the handle to turn the chute. This is from stainless tubing 3/8 O.D. 1/4 inch I.D. I bent the handle as best I could then welded the joint and welded on the rod down to the U joint connection. 32 inches total length. It seems to work fine. Second shot is of the two 3/8 set screws that I need to finish the drive line. I picked up 5/16 dia. set screws by mistake. The third is the left handed belt tightener that I made. Note: I drilled the hole for the castellated nut to close to the handle so I had to turn the nut around. Should work OK since the nut really doesn't see much load. This should be about it for this project. I hope it helps someone as they work on these implements. My guess is I have around $250 in it for bearings, paint, and fasteners and misc items. I guess I will add a before and after shot too. Regards, Chris
#66
Chris, your snow thrower looks fantastic! You did a top notch job on it!
#67
Chris, for what it's worth, I think you did an outstanding job on the thrower, fine looking restoration my friend
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
#68
Chris, Another "SWEET" final product!!!
Clay |
#69
Thanks Guys,
Off to work on another Cub project! Regards, Chris
#70
Beautiful job Chris! Makes me want to tear into one of my throwers...I doubt they would look as nice as yours! Cant wait to see it mounted up!
![]() Jeff (teet)
CCC 1211 71 127 ![]() 102 122 1962 Original |
