Old 02-02-2014, 05:48 PM
Giotundo Giotundo is offline
Ok update. I got everything up front working, I know it took a while. The slot for the key had been all torn up so I had to build it back up to get it to sit nice and tight but it's all good now. Now i'm back to the hydro. It'll move fine forward and reverse but only at low throttle. When given more throttle it won't move either way. I made a video so you hear when the throttle moves up the movement stops and when moved back down it'll move forward and reverse again. http://www.youtube.com/watch?v=ol69L5uxWhE
Old 02-02-2014, 05:57 PM
cubs-n-bxrs's Avatar
When you throttle it up does the stub shaft on the back of the hydro stop turning as well? I still think you have an oil delivery problem. Time to start bird dogging it.
Old 02-02-2014, 08:03 PM
cjrolke cjrolke is offline
fluid level? or something in the suction line or filter?
any leaks?
Old 02-02-2014, 09:38 PM
The shaft is still spinning, fluid level is good and brand new fluid. No leaks, and every section of the line has been taken off and blown out, nothing was in any of them. I have no idea what else it could be.
Old 02-02-2014, 11:53 PM
Did you change the filter a second time like suggested?
Old 02-03-2014, 08:48 AM
Time to download the service manual.
http://www.onlycubcadets.net/forum/s...ead.php?t=4642
I'm thinking you have a problem with the charge pump or one of the relief valves.
Old 02-03-2014, 09:07 AM
New filter is in the mail, I put the original one back in which was working fine before. And the relief valves are both purtruding and move up and down freely.
Old 02-03-2014, 09:38 AM
cuber cuber is offline
How long has the tractor ran since this happened? Is it slowly getting better?
Old 02-03-2014, 12:12 PM
I'm not talking about the check valves, I'm thinking maybe the relief valve for the charge pump has some junk in it or possibly the pin inside the charge pump has sheared. That's why I suggested that you down load the service manual. It explains how to test the hydro and how to service it.
Old 02-03-2014, 06:14 PM
Ok thanks for all the help will get back to y'all soon.
