Old 04-07-2014, 10:44 AM
I bet it will steer easier, Jonathan.
Old 04-07-2014, 03:46 PM
New shoes look great on the front Jonathan!
Old 04-08-2014, 08:07 PM
4BT
Nice tires Jon, like the video too. Question though, I've seen a diesel low boy at my local tractor show that looks completely factory. Is a 4 cylinder with a stanadyne pump, not sure if it's IH or maybe Perkins?
Old 04-08-2014, 11:03 PM
Thanks Mike!
Thanks Alvy! They never made a diesel Lo-Boy, so we at least know it isn't factory. IH never made a diesel that small, it may be a Perkins. Smallest diesel IH made was the BD-154. They used it in the 384 diesel tractor. It was 154 CI, and I suppose it might fit. Originally it had a IH built injection pump on it, but they don't make that pump anymore. AFAIK, the only replacement was made by Bosch, but Stanadyne may have made a replacement. Did you snap a pic? I could probably tell by looking.
Old 04-09-2014, 07:54 PM
gmbadgley gmbadgley is offline
I don't think a 154 would hack a 4BT diesel. The low boys were over built, but to go from a 15 HP to a 65 HP???
Greg
"If I can't fix it, I can screw it up so bad no one else can either"
Old 04-09-2014, 11:37 PM
Greg
I don't think it would hack it either. The 4BT made more like 105hp, I've seen them lower but not much. The 4B, now I've seen them de-rated to like 55hp, but it's still up there around 200ftlbs of torque. That would twist the Lo-Boy frame like a pretzel! I agree. If I were to do something like throw a diesel in it, it would be a 4cyl Kubota. Something in the 30hp maybe 35 range and under 100ftlbs. Even then I'd be worried about the drivetrain.
Old 04-10-2014, 07:51 AM
sawdustdad's Avatar
I think the clutch would be the weak link and would give before the frame? No?
But anyway, I like your lo-boys, Jon. Very cool. I came sooo close to buying one about 6 years ago..I've always loved the look--that low, wide stance, and those big turf tires. There was a 154 in good running shape in Callao, VA that I stopped and looked at a couple times (as my impatient wife rolled her eyes at me). I was trying to justify getting it, but it didn't have a Cat 1 hitch on it, only a belly mower (which looked in serviceable shape). Didn't buy it, then a few weeks later, it was gone. It made me a little sad...They come available here in VA quite often, so maybe someday....
Old 04-10-2014, 11:49 PM
If I were to put a diesel in one, the clutch would be upgraded. The frame on these tractors is very light duty. When I was putting the new tires on the front, I needed to move the tractor. I put a piece of solid square steel stock between the axle and the frame and let the jack down. The frame twisted so much the spindle was only about 3 inches from the floor. I have been trying to figure out how the PO broke the clutch flywheel..... I think he may have gotten the frame in a bind. Then, the side/twisting load on the flywheel from the driveshaft broke the flywheel. It's about the only thing I can come up with. We're going to learn a lot about diesel power in the 582 build I'm getting ready to embark on.
Old 04-14-2014, 01:26 PM
Whizdbiz2 Whizdbiz2 is offline
Greg
They used to put Ford flathead V-8s in Ford N series tractors too. Could be a problem with a transmission and rearend designed for about 23 hp.! Might be OK if you never intend to work it.
Cub Cadet 86
Mahindra eMax 22 w/FEL
Husqvarna LGT2554
John Deere GT275
'48 Ford 8N
'41 Ford 9N
Yerf Dog Scout CUV
Old 04-14-2014, 02:03 PM
jimbob200521's Avatar
I was going to ask which project is going to come first, the diesel 582 or Lo-boy but I think you just answered my question
-Ryan
