Old 12-27-2014, 04:29 PM
2-4 PSI is fine.
Old 12-27-2014, 04:37 PM
Ken
I'd go with the low psi pump. You may not have anything wrong with your pump. The pumps on both my 2182's make noise when they are actually pumping but once the float bowl on the carb fills they get quiet. If you haven't replaced all the fuel lines, fuel filter, tank bushings and cleaned the shut off valves on the bottom of the tank I highly recommend that you do so. I also relocated the fuel pump on the last 2182 I picked up to the same place they mount them on the diesels. They are a royal PITA to get at under the fender pan. I also wouldn't be at all surprised if you don't have a wiring problem to the pump.
Old 01-14-2015, 09:14 AM
Diesel Krazy's Avatar
Diesel Krazy Diesel Krazy is offline
Today I will get some time to look into my fuel pump issue. I have confirmed that it's not a wireing problem and is a pump issue. A few times now the tractor has died because the pump turns off sometimes just after starting the tractor. If I tap on the little black box on the side of the fuel pump the pump will start pumping again and the tractor starts right up and will run for as long as I need it to. After startup and tapping on the pump it will be fine and never die. It only will act up at first start of the day. I need to find out what's inside the black box on the side of the pump, relay mabe? I did purchase an aftermarket low pressure pump as suggested if I cannot get the original pump to be reliable. Yesterday I finally bought a new air filter and noticed the date on the old one. Wow, how do you own a $7k tractor and never replace the air filter in 25 years!! PO's are unbelievable sometimes I just don't understand!
Original- Wheel Weights, AG tires, Brinly Sleeve Hitch, #2 Cart
882- 50c Mower Deck
2182- 60c Mower Deck, Rear PTO, Cat 0 3-Point, Brinly 60" rear blade
Case 646 FEL
Case 446
Old 01-14-2015, 10:20 AM
FrankF3's Avatar
FrankF3 FrankF3 is offline
New Old Stock? Maybe the PO bought some spare filters when he bought the tractor. I still have 1 or 2 old style "IH" branded (Kubota) air filters from the dealer when I first bought my 1572 new.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 02-11-2022, 10:00 AM
Farmall450's Avatar
Here are some other filter numbers for you.
NAPA oil filter 1064
NAPA air filter 6270
NAPA hyd filter 1410
If you find that you need to get into other areas like the trans or need to replace things like hose's or the fan belt let me know, I have the numbers in my file.
FYI for those referencing this...add a 5 or 7 in front and the WIX alternative (same filter, Napa's OEM) has been a lot cheaper lately.
Example Oil Filter WIX 51064
