Old 02-27-2015, 10:57 AM
Found the thread I did a while back about tiller tines.
http://www.onlycubcadets.net/forum/s...ad.php?t=32065
Old 02-27-2015, 03:54 PM
Dang Sam that's a lotta coin for 24 of them....there may be a hard surfacing rod and some steel in my future...the ends are the worst-from rubbing on the tine cover, there's a groove worn into the cover on both ends. I've been wondering what kinda noise that made...
Old 02-27-2015, 04:20 PM
Yep, I'm glad I only needed 20 of them. Wish I had known about that last place I linked before I bought my tines. Think I paid about $220 with shipping. Stupid money for a bent piece of bar stock with a couple of bolt holes. My tines were so far gone that it wasn't worth rebuilding them, I did think about it.
Old 02-27-2015, 04:40 PM
Most of mine are whooped. One side worse than the other(bearing was out on that side so it rubbed more). Some guy has tons of Troy-built tines on ePay, $80 or so for 16. They have 3 holes so they fit more than one make. Hole spacing will work. Not sure if they will fit well or how good they hold up though. Might just be money ahead to buy the OE version and be done.
Old 02-27-2015, 04:57 PM
I spent a bunch of time trying to find tines when I thought they were NLA. The Cub tines if I recall are longer and the bolt spacing is a bit different. I figure what I have now will out last me.
Old 02-27-2015, 04:59 PM
here are 5.
http://www.ebay.com/itm/NEW-OEM-IH-C...item1c4e7ee685
Here are 3
Up to 534 and counting...
Old 02-27-2015, 07:09 PM
Diesel Krazy's Avatar
Diesel Krazy Diesel Krazy is offline
My Case tiller uses a verry similar tine. They were only 8.00 a piece. They look like they could be close. Mine have a bolt spacing of 4 3/8" on center.
Original- Wheel Weights, AG tires, Brinly Sleeve Hitch, #2 Cart
882- 50c Mower Deck
2182- 60c Mower Deck, Rear PTO, Cat 0 3-Point, Brinly 60" rear blade
Case 646 FEL
Case 446
Old 02-27-2015, 07:54 PM
Cub tines are about 3" center to center for the bolts.
Old 02-27-2015, 08:03 PM
Much smaller spacing than mine. Oh well can't get lucky all the time.
882- 50c Mower Deck
Case 646 FEL
Case 446
Old 02-27-2015, 10:50 PM
red211's Avatar
red211 red211 is offline
Drill a new hole, wouldn't that work?
73 149, 73 109, 71 128 with sleeve hitch, decks for all with a 44C on the 149 as the daily mower. front blade and IH rock rake
