Old 03-05-2017, 07:26 AM
john hall's Avatar
Actually John, after the replacement engine, the 1872 is my favorite tractor
Forgot you had that one. I was referring to your current headache, I mean challenge, I mean "project". If you are like me what you refer to it as depends a lot on the latest issue you have found with it!
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 03-11-2017, 04:31 PM
john hall's Avatar
Finally, made progress! Valve stems ground (clearance), valves installed, heads on, valve covers on, intake installed. exhaust manifolds back on.
One small problem, I drove the flywheel side seal in too deep. By the service manual, .080" is the max depth to drive it in--I screwed up and got in close to .150". Looks like I have to order a seal, can't have any luck crossing it over. Anyone got an interchange # for 52-032-10 Kohler?
2072 w/60" Haban
Old 03-11-2017, 04:54 PM
John,
I have a seal here and the # on it is 1177 and crosses over to this one.
Go here and see if it is the same size.
http://www.skfextranet.com/Catalogs/...il.asp?s=14768
Old 03-11-2017, 09:15 PM
john hall's Avatar
John,
That one is too big, this one is around 1 3/4 OD. I'll get a magnifying glass or my son to see if they can make out the numbers on the old one. I can see the numbers, but can't attempt to read them.
2072 w/60" Haban
Old 03-12-2017, 12:07 AM
Yes sir. Bout it, depends on how it's/they are working today.
Old 03-12-2017, 10:26 PM
john hall's Avatar
Don't laugh, here is my setup for grinding the stem clearance. Held valve in V-block an used a mounted stone in a milling machine. To be honest it worked rather well and fairly precise. Probably needed a different wheel, but this one worked OK.
2072 w/60" Haban
Old 03-12-2017, 10:36 PM
Not bad......
I've done with worse set ups and it ended fine.
Old 03-14-2017, 04:00 PM
bill682 bill682 is offline
My notes from a few years ago show SKF 13514 as a replacement for 52-032-10-S - front (flywheel side) crankshaft oil seal - KT-17/M-18.
Check the dimensions and see if they are correct.
http://www.skfextranet.com/Catalogs/...il.asp?s=13514
Old 03-14-2017, 04:52 PM
Terry C's Avatar
Terry C Terry C is offline
Looks like a good set-up to me.
Did you spin the stone as fast as the spindle would go?
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 03-14-2017, 08:21 PM
john hall's Avatar
Yes, that is it! I spent a ridiculous amount of time trying to cross over the Kohler number, the number on the seal, and even looking by sizes--that really puzzled me. The one you listed, however, is not a "rubber covered" seal. Don't know if it makes a difference or not--maybe there is a difference in the sealing material? . There must be something to this as to why you can't find an interchangeable seal #. I can guarantee one thing, the seal I installed too deep was in an aftermarket set--no name and a different # on it than the original. Anyway, I have one coming from a Cadet Collector that needed to thin his parts supply.
I'm afraid to look (so I won't) but the seal you listed is probably on the shelf at 1/2 the parts stores in town.
2072 w/60" Haban
