#61
You're a moderator?
nra1ifer ![]() Cub Cadet 123, Wheel Horse C160, Craftsman PGT9000, Speedex 1631 |
#62
I tell it like it is.
Have been for several years now. Where have you been? If you would like to walk the OP through the process we already walked him through, go right ahead. But it's already been covered, and he has removed 2 already. Nothing new you're going to add. Loosen the set screw, polish the shaft, soak it in penetrating oil, drive the lock collar opposite direction of shaft rotation to unlock it. If that doesn't work, try the other way. If that doesn't work, cut it off. Same process for all 6 collars. What is there to go over??? |
#63
Let me just add (and maybe muddy the waters)
There are self aligning bearings that do not have the eccentric locking collar. They look like any other collar with a set screw or two, but made part of the bearing inner race. USUALLY those style don't have any blind drilled holes for a spanner wrench (where most just use a punch) Someone over the years might have substituted a non locking collar, as they can be used successfully. |
#64
I'm sure it's the original style bearing with a lock collar. I'm sure it's the original bearing period. |
#65
Finally got the lock collar off! The previous owner must have taken it off at one point and also struggled because the pin hole was mutilated...but after soaking in penetration oil a little longer it finally moved. Now the case is open! From what I can tell, the reason why it ceased up was because one of the lock collars on the tine shaft was loose. This caused the gear to move and pinch the chain between the gear and casing. Maybe this is not the cause, but now that I have it open I can get the chain on right and put it back together!
IMG_8211.jpg IMG_8212.jpg IMG_8213.jpg IMG_8215.jpg IMG_8214.jpg |
#66
You need a new sprocket, the teeth are shot.
#67
Good grief, you need a parts tiller!
Mine was not even close to being that bad, the tines were all shot and I doubt if it had EVER been apart. Again, good luck!! |
#69
I don't think the OP's has ever been apart either. |
#70
Copy that!!
Mine did have the remnants of grease in it yet. Was surprised how much the new chains maid in the tightness of the whole unit, once adjusted to the spec's in the manual for a new chain installation that is. |
