Old 11-06-2017, 09:22 PM
sorner's Avatar
sorner sorner is offline
Here you go, Humpty Dumpty...
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
GREEN 317 with integral sleeve hitch, front hydraulic
Old 11-06-2017, 09:40 PM
brudder brudder is offline
Next week at this time my bench full of parts will be a runner.
Old 11-06-2017, 09:54 PM
john hall's Avatar
Looks Great! Since this thread is so long and long-running, how about a recap of what you made that machine from--I see 2 piles of "remnants" in the yard.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 11-07-2017, 03:23 PM
sorner's Avatar
That's the two piles that are visible. I have one big pile out behind my chicken house. I really didn't use much for it. Just a hood and engine. I put new tires on the front and bent the rim out straight. It's a 2284 with a CH18. I dropped in a cast iron rear while I had the tranny apart, so I put the super pump and gears in the cast iron. I mounted a wide frame sleeve hitch lift in the rear plate and made a longer lift arm to go up to the hydraulic ram to lift it. I turned my garden with it already, with my 10" moldboard and it was effortless. I just have the factory cub tires on the back and it didn't spin at all, I thought I would. It was a test run because I was trying to decide if I should splurge for some ags. I mowed with it with my 54" deck too and it did a really nice job. I'm quite happy with this tractor for a little over $450 I have in it.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 01-20-2018, 01:06 PM
sorner's Avatar
Here’s an update for you all. We haven’t gotten a lot of snow here yet, so I’ve only had a little bit of play time. The most recent snow was about 5” here and I couldn’t resist getting this behemoth out to blow away the 5”. I quickly found out I needed chains, so I ordered a set and got them yesterday. I put them on and drove it around today through the snow and what a world of difference they made. I have seen all of the arguments about ag tires va chains, and I decided to go chains with no additional weight to try it since it’s cheaper. The weight of the cast iron rear seems to be plenty. If I need more weight I will add it but so far so good. I love this tractor! Now,
That steering cylinder I rebuild is still working great!
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 01-20-2018, 04:26 PM
Looking good, you need some big snow for that blower, hope you get some.
On a side note your left chain is on inside out.
Up to 534 and counting...
Old 01-20-2018, 04:28 PM
sorner's Avatar
You have a sharp eye. I didn’t know they had to go a certain way, they didn’t come with instructions.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 01-20-2018, 04:38 PM
john hall's Avatar
I got a "Southern" question. Do you have to crowd or "push" a blower that big to make it work properly? My thinking is kind of like running a combine or baler, you have to "feed" it adequately--too slow creates issues.
2072 w/60" Haban
Old 01-20-2018, 05:39 PM
EricR's Avatar
EricR EricR is offline
John, we have a 551 blower on a 2284 and to it it does not matter, I have never plugged it in any snow in all the years we have used it!!!
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 01-20-2018, 08:00 PM
sorner's Avatar
Mine is a 551. I rammed it into a pile of wet melting snow today and it handled it like it was feathers. Slow or fast I have not seen it break a sweat.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
