Old 01-04-2018, 11:21 PM
Gompers Gompers is offline
Originally Posted by Slycox View Post
Thanks for the information, I did buy just any coil and I checked before installing it to see what it was reading. Was right at 3.6.
After getting the new coil, she lives! Seems to me that the motor wants to run a bit fast so I will have to tune the carb, the mysterious no start popped up again I believe its tied to the foot pedal after pushing a few times it went.
Did drive it and it seemed ok in the gears, will probably need motor mounts that were mentioned somewhere it does shake at low rpms, but overall I'm happy. I can start fixing the issues now that it runs.
Thanks much for your help
Woohoo!!
There's a little metal flap under the middle of the tractor on the brake shaft thing that pushes a switch when you push the pedal all the way down. Sounds like it needs adjusted or cleaned (a lot of people bypass that one, especially on hydros).
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240
Old 01-04-2018, 11:47 PM
Slycox Slycox is offline
Originally Posted by Gompers View Post
Woohoo!!
Yep found that one. Pretty grimy down there, next step will be cleaning and going through everything to see what is needed.
Old 01-05-2018, 01:12 AM
Glad you got it running. More glad you lucked out with a correct coil.
High idle engine speed is controlled by the governor, not the carb. Carb adjustments set low idle only. Download the K series manual for governor and carb settings/adjudtments.
Hydro tractors don't have "gears".
Old 01-05-2018, 06:40 AM
twoton twoton is offline
Good to hear you got it going.
On a side note I have noticed that you may have exceeded your words to picture ratio in this thread...
Old 01-05-2018, 11:09 AM
Good to know, I do plan on downloading the manual and working through all that.
I wondered if someone would say something about the gears...
So your that guy around here
I've attached a couple pics of the of the coil stuff the way its setup with the old coil and the old an new one. Most of the pictures I've taken lately have been so I can put the thing back together.
Old 01-08-2018, 10:59 PM
Started tear down and cleanup today, overall every thing looks to be in ok shape. The fan on the shaft has a broken blade, a few scrapes and alot of dirt but I haven't seen anything that bad yet. Haven't seen any major leaks, possibly some minor ones.
Will work on cleaning some more the the next few days then probably fluid changes etc. Thinking about rewiring the whole thing a few old connections etc
A couple questions that I have. Are the directions for hooking up and operating the attachments in those manuals or should I look somewhere else?
Also as far as the rear pulleys/pto is it continually running or is it there a switch for it? I haven't been able to find information on the setup I have.
Edit: Also is there any benefit from tearing down further? Would it be worth it to pull the motor and replace the mounts?
Old 01-08-2018, 11:12 PM
MLamar on this site sells new wiring harnesses. Here is a link to his web page. Good product, good price. WORTH IT.
http://www.mikescubcadets.com/
Yes. Some of the instructions are in the tractor operators manual. Most are in the Operators manual for the attachment.
That is a tiller drive gear box. A long belt goes from the front PTO to the lower pulley on the gear box. It runs off the front PTO. Switch is on the dash. When the belt isn't on it, it's just a "pretty" to look at.
Yes. To both. Lots of worn part you haven't even begun to get to. Only thing I see you did was take the hoods and fenders off of it. Not much you can fix until you take it down further.
Old 01-09-2018, 01:00 AM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
I was going to do just the basics on this 1650. Plans were for cradle mod, new drive line components, engine mounts, some gaskets and the trunnion repair. After pressure washing it I found some cracks in the frame. Sooooo, since I had to take it down to the frame, I figured i might as well go for a full restoration. This project is still in process. Take it down, find and correct the issues of a 40 yr old tractor and you will have a great machine with many more years of service.
http://www.onlycubcadets.net/forum/s...ad.php?t=48986
Queen Of The Quietlines!
