Old 06-05-2018, 09:54 PM
I agree with what Beth & Jon have said.
Yes, you should have it bored and all the other good stuff.....
If you break into an Onan you best plan on spending some coin.
You will probably need new pistons, rings, rods, cam bearings, probably crank bearings, have the crank turned, all gaskets and then have it bored to do it properly. That will probably set you back near $1k.
Or say WTF and throw a set of $60 rings in it to see if it runs. Ya, it might be half a$$ed but if it runs okay then maybe you can plan on a full rebuild.
$1k is still cheaper than buying a new Kohler, Vanguard or Hazard Freight Predator engine.
Sorry...that is my
Old 06-06-2018, 06:05 AM
sorner's Avatar
sorner sorner is offline
All good and convincing information. I don’t have that kind of jack to throw at it so this project is over. I was under the impression all I had to do was break the glaze and throw some rings in it if everything else was pretty. This is why I was throwing in the towel on it, and Jonathan said I give up too easily. No, I just don’t want a money pit. Because of this I decided to just run the M18 in it for now until it needs a rebuild and go for the full rebuild with it when the time comes or repower. I’ve got in and all hooked up except for a relay for the ignition relay to kill the engine with the old points/coil power line to ground out the coil to kill the engine. I have the relay and know how to use it, I just need to pick up some connectors to make that all happen. That was the original plan I was going to do and I’m back to that. I can return the ring and gasket set, so no big deal except I’m out shipping costs.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
GREEN 317 with integral sleeve hitch, front hydraulic
Old 06-12-2018, 01:12 PM
sorner's Avatar
The 1912 with the M18 installed runs and sounds beautiful. And I like how the 50” deck cuts.
Temporary relay wiring, I want to get a socket to plug a relay into and wire it properly, as well as a three prong plug that’ll fit into the engine harness for the 12v, magneto, and oil light to make it look more professiknal.
It gets the 2 year old son seal of approval. He loves tractors.
All dressed with the heat shields and hood on.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 06-13-2018, 10:34 AM
Very nice 1912!
