#61
Very inventive method of shake rattle and roll with screener. Maybe a few more times with it? Where did you source the other tank? Aftermarket?
I haven’t tried that red kote stuff but have heard decent reviews. Probably based on the interior of the tank being rust free though?
#62
I do not see any rocks, is the new tank a direct replacement or do you have to make it fit?
Up to 534 and counting... I give up updating my profile! |
#63
Rocks are in the bucket, first picture
#64
![]() I've used Kreem successfully to seal other tanks, like this; https://www.onlycubcadets.net/forum/...593#post455593 ...with great results, but.. it takes time to do it right, and I figured at a buck 25 for a new tank I'd just get a new one. Anyway... |
#65
I have to make the new tank fit... right back in the cardboard box that it came in!
#66
I finally scraped away enough crud and paint to find the serial number;
D1414C 3D24B *C378015* D – Ford 4000 14 – Who knows? Maybe ‘Special Utility’ ![]() 1 – diesel 4 – Independent 540 PTO C – 8 speed manual trans 3 – 1973 D – April 24th day of the month B – Day shift C – Built in the good ol’ USA! ![]() 378015 – serial number |
#67
Time for a quick update.
After not being able to get a confirmation from Ford/New Holland as to the proper tank for this Ford 4000 SU I decided to take a chance and order the tank listed for a Model 3000, and guess what? Yup, it fits! So, along with the new tank I installed a new fuel level sending unit, lock ring and sealing gasket. Also new fuel tap/shutoff,..and yes, there is a difference between the WIX filter that claims to be suitable for a CAV fuel system and the OEM filter. |
#68
The only difference between my new pump and the old one is the side cover plate. The original just had a blank plate but the new one has the provision for a return to filter line. Both it and the filter housing threads were 1/2 - 20, so I ordered a couple of SAE 5M x 1/4" NPTF adaptors ( I actually removed the o rings that came with the adaptors and replaced them with some copper washers that I had.
That's it. New fuel system complete.
#69
Tanks for the update, any other issues before you try to start it?
#70
That’s coming along nicely, keep up the good work!
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart ![]() ![]() ![]() ![]() ![]()
| Tags |
| cav injector pump, ford 4000 su |
