Old 09-19-2019, 11:48 AM
CC2140 CC2140 is offline
Man I want a dually setup so bad. Once I buy a deer property, that will be one of my first items is a GT with PTO so I can run a tiller for small food plots and dually wheels. Nice job!
Old 09-19-2019, 03:13 PM
You will constantly have wheel tracks in your freshly tilled ground w/duals.
Would not make for a very good looking till job when finished.
If anything, you will need some weight up front.
Them tillers are heavy!
Old 09-20-2019, 09:31 PM
Cub70's Avatar
Cub70 Cub70 is offline
Thanks! I have one rim sanded, primed, and painted. Still need to do the other rim. Just been a rough few weeks, haven’t been able to get out to the “70” lately.
Once I’m done, I will post up some finished pictures.
1964 Cub Cadet 70 (Full Restoration), Upgraded/Rebuilt K181 8hp engine, custom exhaust stack/flapper, NEW clutch, brand NEW steering column, Custom made wiring harness w/ammeter, LED headlights and tail light, Custom 2” receiver hitch, Custom pull behind paint matched trailer
Old 09-23-2019, 08:16 AM
Cub70's Avatar
Got some pictures of my new air cleaner base (larger air filter, better air flow), new air cleaner cover, new custom made spark plug wire (stranded copper core), and re-jetted carburetor:
What I removed:
Old 09-26-2019, 04:46 PM
Cub70's Avatar
One rim and tire completed! One more to go:
Old 10-01-2019, 08:36 AM
xcookpac xcookpac is offline
Nice work!!!! You give me inspiration to get my stuff done.
Old 10-01-2019, 10:09 AM
Cub70's Avatar
Thanks! Remember to take lots of before, during, and after pictures!
Best of luck!
Old 10-01-2019, 07:59 PM
Looking good!
Old 10-06-2019, 12:22 PM
Cub70's Avatar
Got the dually adapters and dually adapters lug bolts on:
FYI, for those of you who didn’t know, you can NOT mount the outer dual rims/tires with the mower deck on. The outer duals hit the mower deck wheels/mounting bracket. So the mower deck must come off to mount the outer duals.
Old 10-07-2019, 10:36 PM
IHscout79 IHscout79 is offline
Nice work. Can’t wait to see the tractor with duels!
Justin
