Old 10-23-2019, 10:29 AM
cooperino's Avatar
It would seem you got a defective carb or it was wrong size
Old 10-23-2019, 11:32 AM
Rwgarrison23's Avatar
Rwgarrison23 Rwgarrison23 is offline
Originally Posted by cooperino View Post
Yes, you should be able to dial it in now
Still doesnt change how long it takes to fire up tho.
Or my points still set wrong or like you said I have weak spark. Or try a different spark plug.
Old 10-23-2019, 12:12 PM
cooperino's Avatar
You can verify spark with plug out and grounded. Also. There should be no sparking at the points. Take a look at points with it running
Old 10-23-2019, 12:18 PM
I'll buy a spark plug tester and take the cover off and have a look. I'm going to put autolite 216 in and see as well. Set it at .035.
Old 10-23-2019, 01:49 PM
If the points is sparking while running then what does that mean?
Old 10-23-2019, 03:32 PM
cooperino's Avatar
Check your grounds... You may have had a couple issues going on here
It could also indicate a bad condenser
Run a temporary ground to Neg side of coil from battery and see if it stops arcing.
Old 10-23-2019, 04:03 PM
I installed brand new wiring harness as well. Main harness and headlights. I made sure everything is cleaned and free of corrosion. I had this thing completely apart and cleaned lol.
Old 10-23-2019, 04:20 PM
Points are not suppose to arc,
BUT in the real world, ya they do a little every time they open.
Also if they are dirty, they will arc more.
Old 10-23-2019, 07:38 PM
So this is interesting. Changing out the spark plug to autolite 216 and gapping to .035 seem to solve everything. 2 full rotation with choke on and half throttle and engine fired up then i gave it about 5 seconds then cut the choke off. Runs fairly smooth. The champion plug took almost 6 or 8 rotation before it fired up. So, I let it warm up and cut her off. I will try again in about 30 minutes and see what she does.
Unfortunately my kohler is burning oil, haha. Blue smoke. So for now to get me through the winter, I put 15w40 rotella. It sits in a climate controlled garage, so starting in cold wont be a issue.
I did not take my points cover off yet to see if its arcing. I will do so just in case.
