Old 01-06-2023, 08:13 PM
Farmall450's Avatar
Originally Posted by Radioguy41 View Post
I guess depending on how you look at it this qualifies as a tool. I bought a vehicle battery starter pack back in Sept just as a precaution. Jump ahead a bit and I'm sitting in line ready to set up at the antique radio show and when the gates opened the guy in front had a dead battery. Aha, time to test the new tool so I hooked it up, he hit the key, and the engine fired right up. OK, good enough for me so I bought a second one and now there's one in each vehicle. At $57 you can't beat it. It can even charge your phone.
https://www.amazon.com/dp/B099DRPRKD...t_details&th=1
I've had good luck with the Noco brand. It will be more than $57, tho.
Old 01-06-2023, 08:14 PM
Farmall450's Avatar
Small hose pinch pliers from Napa (same as Gearwrench - KD USA) #3791
Old 01-23-2023, 02:41 PM
Radioguy41's Avatar
Radioguy41 Radioguy41 is offline
After 60+ years with a manual calipers I jumped off a cliff and went modern. Brand new digital calipers. Does the standard OD, ID, and depth and in three measurements, mm, inch, and fractions. For $20 on Amazon I figured I wasn't risking much but I've used it a few times now and I'm liking it! Every measurement I've checked has been spot on.
2005 CC GT2544
1980 IH CC 782
1957 Cub Lo-Boy
1993 Craftsman LT4000
Old 01-24-2023, 07:17 AM
I have had a Makita for prolly 30 years no problems
Only replaced a couple of 357 batteries.
But for precision work I still rely on various mikes of approiate sizes.
Old 04-05-2023, 09:13 PM
Radioguy41's Avatar
I saw this on Amazon the other day and for $30 I decided to give it a go. 3 positions for the chains plus the screw adjustment for fine tuning engine balance and 1,500 lb capacity. Works great with the electric winch I installed last year.
2005 CC GT2544
1980 IH CC 782
1957 Cub Lo-Boy
Old 04-05-2023, 09:48 PM
I have the same one on my chain hoist Radio. It makes pulling engines and other heavy stuff a little easier. I got mine at Hazard Freight but your deal was better.
https://www.harborfreight.com/3-4-qu...t+load+leveler
Old 04-06-2023, 09:49 PM
Farmall450's Avatar
Won a little Smithy 1324 IMX Granite 3n1 machine from auction. Looking forward to picking it up next week and making/modding some parts.
