Old 09-16-2022, 01:12 PM
Don't Know, will have to look.
There were hawked as the original supplier for Cub Cadet.
Old 09-16-2022, 02:38 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
If it was the high back steel framed vinyl seat with only two bolt patterns, then it is one in the same.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 09-26-2022, 08:32 PM
1711Cub's Avatar
Wink
I had a relatively small yet nagging oil leak originating from the oil plug. One of the previous owners used a rubber seal on the oil plug. Kubota specified a copper crush washer. Not risking that the threads were questionable, I purchased a new plug and correct copper crush washer. Time shall tell if this corrected it. The rest of the engine is dry.
Old 10-01-2022, 05:26 PM
1711Cub's Avatar
Thumbs up
Since I remedied the air filter issue, the fuel filters were next on the agenda. God only knows how old these were. There was a small amount of sediment/dirt in the bottom of the main filter cup. No issues with the initial startup. It ran great as usual.
Old 10-13-2022, 09:19 PM
1711Cub's Avatar
Cool
New Maple Hunter decals
Old 10-14-2022, 08:16 AM
jbrewer's Avatar
jbrewer jbrewer is offline
That looks great!
The guy that redid the 782D I own used the MH decals, I'm pretty sure. They have held up very well with time.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 10-14-2022, 09:05 AM
1711Cub's Avatar
Lightbulb
Thank you. They are made from high performance 3M vinyl decal material. While they are very close and look great, they are not exact to the originals. The original decals were made from a foil, and were whiter. These are more Cub Beige and made from regular vinyl material.
The IH logo was spot on. Their tunnel cover decal wasn't even close to the original. The large diesel specific under hood decal was spot on.
Old 10-14-2022, 03:43 PM
Farmall450's Avatar
Maybe the tunnel cover mimics an earlier/later tractor?
Old 10-14-2022, 05:24 PM
1711Cub's Avatar
Thumbs up
Could be. Not a big deal, since my tunnel decal is in very good condition.
Old 10-15-2022, 07:30 AM
1711Cub's Avatar
Wink
I've sent an email out to Maple Hunter Texas asking them if they have any intention of producing this seat decal which is correct for all of the 1982-up MTD CCC machines.
