Old 01-14-2010, 01:10 PM
First pic of 2010! The 100 has been sitting, since I hauled leaves in December. It fired right up! Not bad for sitting two weeks, so I went for a ride.
Old 01-14-2010, 06:59 PM
bignastyGS's Avatar
bignastyGS bignastyGS is offline
Today, I received the rear bushings that weld to the frame that hold the 3 point hitch lever between the frame from Scott Murphy and I cleaned them up,welded them in and hooked the 3 point hitch up. Now I need to get me a used cheap Brinly adapter and I will be closer to plowing this spring...Also today, I had the weight brackets welded up for my custom rear wheel weights. I copied Merks idea and had a 1/2 plate cut out to fit inside the wheels and welded a 1 inch thread rod piece on so I could slide some barbell weights on. Tomorrow a buddy at work is making some 1/4 plates to cover the barbell weights. When the weather turns nicer,I'll paint them Cub white..
Pat Harmon
Loganton,Pa
128 Cub Cadet
1200 Cub cadet (Red)
LT 1042 Cub Cadet
1200 Cub Cadet
165 Hydro John Deere
1941 John Deere H
1950 David Bradley 5756
1952 David Bradley 57561 Super Power
Old 01-14-2010, 07:34 PM
ACecil,
100 looks like it is enjoying getting a little sun.
bignastyGS,
Sounds like you are getting closer
Old 01-15-2010, 05:42 PM
camarokidz28's Avatar
Default Diz Jr. Got the MONSTER BLADE Out
Diz Jr. I am going to put chains on all the back tires . Wont be till i go next Saterday to pick the 70 he has 2 set's of 23 x 10 .50 x 12 chains . Here it is wating for snow
Denny
Original Member # 389
Saw It
Wanted It
Had A Fit
Got It
Old 01-15-2010, 06:27 PM
That is one good looking tractor camarokidz28
It ought to be pretty much unstoppable with chains on all those tires :biggrin2.gif: That rig makes mine look like a toy
Old 01-15-2010, 07:54 PM
bignastyGS's Avatar
Mounted the wheel weight brackets on the back today and cut the 1 inch thread rod flush with the nuts so they don't stick out. Decided to only put 4 10 lbers on each side,but I need to run to Dicks Sporting Goods and get 2 more. I like the way it came out and now need nice weather to be able to paint the whole deal..
If I am boring others,please say so...I am really enjoying working on these tractors anymore...It's a nice change and fun thing to do in the cold months..
Pat Harmon
Loganton,Pa
128 Cub Cadet
LT 1042 Cub Cadet
1200 Cub Cadet
1941 John Deere H
Old 01-15-2010, 10:57 PM
Love hearing about your progress bignastyGS
Old 01-15-2010, 11:12 PM
Thanks for the pics, camarokid. Can't wait to see some action pics.
Old 01-16-2010, 06:36 PM
CBH's Avatar
CBH CBH is offline
Default Spring cleaning
Well......it seemed like springtime here today! Almost 50 degrees!
I used the 124 and the old cart to help move a few items from the garage. It was really nice to be able to work in the garage with both doors up!
Old 01-16-2010, 07:07 PM
Was a busy 2 days weled up some rims for the puller and painted them .
Making a 6 wheel trailer painted the rims to day and was working on the frount axle .
got the peices for the frame cut .
Have to make a trip to the metal place this week to get the rest of the steel i need .
Denny
Saw It
Wanted It
Had A Fit
Got It
