#71
Nice upgrade! I like the "well" for the grease fitting you made
#72
It's obviously homemade, I won't be winning any prizes for looks, but it does work well.
http://www.solunagarage.com |
#73
Moving forward!
Cork gasket was in severe need of replacement, and I also picked up a rear lift assembly and sleeve hitch adapter! So pumped!
#74
Nice additions! Seems like every hydro I get, the cork gasket needs replaced- almost a given! Having the tractor clean is more important than anything, which looks like yours cleaned up good
#75
Got the rear lift installed, added greaseways and fittings for the main support pivot and lift arm attachment at the rear of the tractor (basically the other two pivot points). Moves nice and smoothly.
It's also leak free now. Real nice to to not have to put shop rags under the tractor every time I park it. Relined the brake pads too, let the glue cure overnight and will install next weekend.
#76
That cub sure lucked out when it found a home at your place.
Great work and photos. John
#77
Thanks guys! It makes it even more rewarding when you have a community to share your progress with.
#78
By the way, what type of glue did you use for the lining?
#79
QL is looking good & I'm liking that heavy duty tail light in the 3205.
I've used JB weld to reline a few brake pads. Clean everything up good, mix & apply the JB then stick'em in the vice overnight.
#80
I used what I had in the shop, which is Seal-All. It has a relatively high tensile strength and resists oil and gasoline. (Not that the braking system really sees either of those). Had JB Weld too, as Oak suggests, but I wanted to give this stuff a try. More curiosity than anything else.
