Old 11-17-2012, 11:33 AM
You do excellent work!
Old 11-17-2012, 10:22 PM
EarlJ's Avatar
EarlJ EarlJ is offline
I sure wish I had your skillset, I do a hopping weld..lol.. I'd say you have a small fortune in that set up so far. I am kind of thinking I could put a removable set up on the ol 126. We don't get much snow here so would only really need it for the work I do to keep the cold air off me. Now I am contemplating air conditioning for the summer gardening...
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Old 11-19-2012, 07:33 PM
xtreamedrtbker xtreamedrtbker is offline
Thanks guys. Hoping to get some work done this week on it, but we'll see how that goes.
Looks like the PTO adapter on my 2182.
I was going to get one from a 3 cylinder and see if it would work, but I figured it was just the same to build one from scratch.
Old 11-20-2012, 12:43 AM
Test fit the PTO clutch tonight. The clutch came from a LX188. The datum diameter is a touch bigger, but I don't think it will be to far out of line for the blower. If there is a problem I can always put a bigger pulley on the blower.
A look at some of the things I do.
http://www.facebook.com/KarvonensGarage
Old 11-20-2012, 12:47 AM
Very nice! Enjoying the updates!
Old 11-20-2012, 07:37 AM
I have two questions for you. What did you do to keep the clutch from rotating and what is your plan for a fan drive for the radiator?
Old 11-20-2012, 08:21 AM
Got to thinking about your heating and cooling setup. As I recall you went with electric heat when you started this project and it had the Kohler engine. Now that you have the water cooled Kubota, would it make more sense to swap the electric heat for a heater and use the engine heat in the cab? I’m just thinking it would be less drag on the alternator not having to power the electric heater along with the PTO and lights. Kubota’s are not known for having much when it comes to alternator output.
Checked out your facebook link, very cool stuff!
Old 11-21-2012, 08:51 AM
CadetTY's Avatar
CadetTY CadetTY is offline
Looks like a great build. Stuff like this makes my mind run wild!
Old 11-25-2012, 07:26 PM
Anything new on this project?
Old 11-26-2012, 12:38 AM
I'm going to run a small electric fan off of a Honda cbr1000rr because of the small size and fair amount of air flow. The electric heat will stay in place and I have added a small homemade heater core from 1/2" od copper tubing and copper plate all soldered together over top the electric set up. I have started plumbing the heater core lines tonight and so far so good.
I wanted to keep the electric core because the power supply runs to the back of the machine so I can plug it into the wall and preheat the cab, then once its up and running I can plug back into the inverter and use the electric heat with the water heat if I need the extra warmth.
I also got the clutch stay made tonight and I am happy with the fitment.
