Old 12-10-2011, 07:18 PM
Sharp 2182 and blower!
It looks massive too!
Old 12-10-2011, 07:19 PM
Originally Posted by ROWDY72 View Post
Here are some pics just waiting for snow now , mounted weight on rear of axel still thinking of plan for cheap wheel weights
Sweet set up! Have you loaded the tires yet?
Old 12-10-2011, 07:31 PM
ROWDY72 ROWDY72 is offline
Here are some pics of an idea I used from an ebay item . A universal wheel weight set up very cheap to do That ebay sellers desighn was slightly more complex But here is what I came up with. 1/4" X 1 1/2" -2" flat steel common size any hardware store , ect. I cut mine 10 in long marked holes from back side of the 4 sqare mount holes drilled them out . Temporarly bolted them in ( use 2 1/2" washer to fill gap of the top piece of steel that overlaped the other ) tack welded them & removed to fully weld I did both sides. I used a piece of 3/4 " Gas line pipe statered with 18" pc. smallest Menards had. Started at 9 " each side centered it on the Now cross shaped metal & welded into place . Used 8 1/2 " Zink cariage bolts running them in from back of rim & boltd into place. I ended up cutting off about 2 in. of the pipe on each side . Slide on my 10 lbs. steel weight That I already had sitting around the house . & I drilled a small hole at end of pipe ( May be easer as I found to drill this priar to welding pipe) Used some spring pins I had lying around Knew I'd use them someday , & I had to fill a small 1 1/4 " gap with a small piece of fence post that slide over top of pipe , or could just add an extra weight ?? I have 30 lbs on each wheel costed me less than $10 but I already had some of the materials like the steel so may $25.00 if you bought the steel new about 40" of it. I now just need to paint the old rusty steel weights : BlahBlah:
Old 12-10-2011, 10:34 PM
Nice cub, ROWDY72!
Old 12-11-2011, 09:00 PM
Nice cub, ROWDY72!
So true! Someone on here has been using that stye of attachment of weights for a while now. Good system to use. Thanks for all the pics too!
I had the tractors out today and forgot to take pics of the snow removal team!
Old 12-11-2011, 10:32 PM
Old 12-11-2011, 10:35 PM
EricR's Avatar
EricR EricR is offline
Nice going there Duke, LOL.
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 12-11-2011, 10:37 PM
Musta been all the cake and chili I've ben eating this weekend! I'll get them posted this week!
Old 12-12-2011, 07:23 AM
Kayak Don What is the green car next to the cub a Corvair ?
