#71
I think for the lube, the best thing to use is a mixture of 80/90 weight gear oil and grease.
AJ
1980 [COLOR="Red"][/COLOR]482- Stock 1981 [COLOR="Red"][/COLOR]582- Mag18, Sleeve Hitch, Spring assist 1979 [COLOR="Red"][/COLOR]682- Mag18, Sleeve Hitch, Spring Assist, #1 Tiller 1980 [COLOR="Red"][/COLOR]782- Mag18, Sleeve Hitch 1983 [COLOR="Red"][/COLOR]982- Stock, Fully Optioned |
#72
AJ,
I think I could do that. I have some grease need to get the 90 Weight oil. and some bearings ![]() Here are some shots as I played in the shop tonight for a hour or so. - belt adjuster cleaned for priming - pulled drive cover from rust tank with hand wired brushed rinsed and dryed - then used the cup wire brush on 4-1/2 grinder to better clean the surface. - welded up the two broken holes with the HF MIG. - and added some primer (looks better) - shot of the center spade or fork in white. Regards, Chris
Casbohm Maple and Honey www.mapleandhoney.com Cubs: 147R and the "train", 127 elec lift, 127, 125, 106, 102, 100, 86, 73, Brinly plow, Snow thrower, 2 Rototillers, several mower decks and several snow plows, #1 cart, Grandkids barrel cart. |
#73
You go Chris. You is one busy boy
![]() Looking good again as I knew it would. I'm blasting the 100 tomorrow, so I should have some pics. soon. Enjoy yourself.
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
#74
Todd,
Thanks! I may not do much if any filler work on these covers they are going to get trashed in the clay we have, if I every put this into action. Bearings are coming and I should be able to start assembly work in two weeks. Great that you can get to the 100 and start blasting. That means you have done a heck of a lot of work your self to get to that point. Looking forward to the pictures of the frame! I like Matt's idea of hidden bolts to put the tunnel back on. Are those in place? Regards, Chris
#75
Looking good! It cool you still have the center fork for it, the one on mine was broken, need to find one
149 with kwik-way loader,1772,two 1782 super smokers, 982 SGT w 54" haban blade,60" haban deck, 50in deck cat 0 3 point, brinly cat 0: blade, plow(3), disc.123,hydro lift. 61"O" Brinly single row planter,brinly cultivator,#2 trailer,brinly 10 inch plow,3 42 inch blades,Model #1 Tiller with extenstions,haban sickle mo. 106w/ags and hydro lift. ![]() |
#76
Humm is right I may know where there is one too?
After a little further review I think the extensions were put on this unit about 10 -15 years after it was new. The tines are more wore on the i center sections near the drive box, and the sheet metal was not as rusty. Regards, Chris
#77
Looks fantastic, Chris!
#78
Cleaned and primed the other side of the case. This is the flat side with the welded bosses. That was about it for tonight. To lazy to take pictures
![]() Hope things are good in Cub land! Anyone ever sharpen their tines? Regards, Chris
#79
![]() ![]() ![]() Third time is a charm? Yea these case halves look a lot better with the grease and rust removed! I think I can save the drive chains. Regards, Chris
#80
Excellent job, Chris!
