Old 06-27-2013, 12:54 PM
cubby102's Avatar
cubby102 cubby102 is offline
The original has got a new look! Will be much better when I can order the ags and tri ribs
I plan on running three sets of weights eventualy
Old 06-27-2013, 12:55 PM
not bad
Old 06-27-2013, 12:59 PM
cubby102's Avatar
Keep in mind the wheels are going to get blasted and painted . But not until everything else is done. Once the wheels shine I can call this project finished
Old 06-27-2013, 01:00 PM
cubby102's Avatar
The twins sittin cosy in their spots
Old 06-27-2013, 01:16 PM
I like the duals! The O's are looking good!
Old 06-27-2013, 04:00 PM
X2!
Old 06-27-2013, 10:40 PM
jcsmith jcsmith is offline
Default steering box seal
Cubby102 , Did you ever get a seal for the lever on the steering box? I've used shipping foam to make one and it worked great. I read on here somewhere that another member did the same , just can't remember who it was. Also on my 104 I used a wheel bearing instead of the bushing in the top of the column. It was a little loose, so I wrapped a few turns of aluminum tape around bearing until it fit. BTW your progress is looking great. I know how it is working on a budget. Can't wait to see it finished. Chris
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
Old 06-27-2013, 11:38 PM
cubby102's Avatar
I actualy ended up making one out of a foam precleaner off my old 782 I'm now sure how it will hold up I will pull it apart and check it come winter. If it qorks ill just make a new one if not I will probably use the shippiny foam
