Old 01-02-2014, 01:28 AM
CTRUEX CTRUEX is offline
You keep on talking about doing a restoration on her, but it looks like new from here. Looking good, Sam!
Old 01-02-2014, 06:46 AM
1811woody's Avatar
The brown truck showed up today with a couple sets of SGT rear end braces from Xtreme. Now I can get into the backend of the 1782. Got the gauges all hooked up and most of the wiring back together/ Hope to give it the smoke test tomorrow before I pull the tranny out. I like the brown truck.
Sam how necessary are these rear end braces I plan on using a plow and maybe a rear blade on my 1872 Is there a chance of breaking something?
Old 01-02-2014, 07:19 AM
Cory
It's not bad but it has a few places where the paint is starting to peel. Normal Cyclops issues. BTDT. I'll just touch it up for now.
Old 01-02-2014, 07:29 AM
Woody
It all depends on how hard you use it and how much you twist the frame. I'm convinced that the twisting is what cracks the pump adapter mounts. The Supers being longer just make the problem worse. I'll put it this way, after replacing the pump adapters on 2 rears out of Supers and having to remove broken bolts on a the rear from an 1863 I put the braces on all my stuff. The first pic is what my 2182 looked like the second pic is from the 1863.
Old 01-02-2014, 11:18 AM
105_Tom's Avatar
105_Tom 105_Tom is offline
Everything is looking good, Sam! You make it all look easy, but it's all about having the right tools and patience to do it right the first time! We'll be waiting for the next installment!
Tom
105, 149 w/44A, #2 & #4 carts
782 CCC Red w/44C
1512 Smoker w/50C, 450 Blower
2072 w/60" Haban
IH/Lawnboy 3322 Pusher, Scag TT 61"
JD 455, X495, Kubota 2150, Gravely 450, 812
Old 01-03-2014, 01:27 AM
1811woody's Avatar
Woody
Yah I'm thinking I'll add those on the super just for a little piece of mind. Thanks for the info Sam
Old 01-12-2014, 04:35 PM
Pulled the rear out of the 1782 today. Popped the axle tubes off, had the normal nasty crud in the bottom of the tubes. Will be drilling the oil return holes, new tube gaskets, axle seals and a set of my braces on it before it goes back in. Got the braces painted. If the weather is decent tomorrow I hope to get most of it done. I’ll get some pics tomorrow. You guys are not missing anything exciting. Pretty much the same old stuff I do on all of them.
Old 01-12-2014, 04:48 PM
How big a hole do you drill Sam? I don't recall if you ever said. Maybe you did and I missed it.
Glad it's warm enough to work in your area again! It's like 45 here today. Wayyyyy better than the -15 at the beginning of the week!
Old 01-12-2014, 05:22 PM
Jon
It was 55 here today.
I drill a 3/8" hole at the bottom of the main case. This is my 2182 but the 1782 will be the same setup.
Old 01-12-2014, 07:21 PM
1811woody's Avatar
I've been wondering how your project was going we haven't heard from you for a while. Is the lack of heat in your garage holding you up?
