Old 09-24-2014, 10:43 AM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Tacosteelersman, I've just sent you a PM with some info in it......
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Tacosteelersman's Avatar
Tacosteelersman Tacosteelersman is offline
I was just informed of a site that can save money on kubota parts, I have not been there yet but will check it out http://www.m-and-d.com/ I was also informed of copper sealing washers that go on the valve cover (head cover) that I should get to prevent weeping of oil. Thanks For the heads up on these details. Frank.
Ok after visiting that site there are some things priced lower and some priced higher. Typing the part numbers in the search box makes this site quick and easy to navigate. So when shopping I will add this site to the list. Thanks again.
Washers ordered. 60 cents each. Cheap insurance.
3 original cubs
1512 diesel
Ingersoll 3012
John deere 855
Old 09-24-2014, 12:15 PM
Yep, they're good and these folks have some good prices too.
http://www.yachtsupplydepot.com
I have not ordered from them but I have from Messicks with great results.
Old 09-24-2014, 12:16 PM
Originally Posted by Tacosteelersman View Post
Does anybody have suggestions on what compression tester to buy? Preferably one with the right fittings.
I suggest seeing if you can rent or borrow one from your local Kubota dealer. You really don't need to own one. Your only going to need it one time. I doubt once you get the tractor running you ever need it again.
Old 09-24-2014, 01:05 PM
Great leads guys. http://www.yachtsupplydepot.com/ Added to the shopping list. This site is also easy navigation when you have the part numbers. Some parts are cheaper some are more expensive.
I will look into renting a tester. It's a good point probally a 1 time use item.
3 original cubs
1512 diesel
Ingersoll 3012
John deere 855
Old 09-24-2014, 01:32 PM
There are some on fleabay for less than $50...probably a pos but might be okay for all we need them. I think Autozone & Advance have a tool borrow/rental program too.
Old 09-24-2014, 01:48 PM
I think if I was going to buy one I'd try this one from Jegs.
http://www.ebay.com/itm/JEGS-Perform..._Tools&vxp=mtr
I would call and find out if the set includes an adapter that fits the Bota.
Old 09-24-2014, 01:54 PM
None of the stores around my area rent out diesel compression testers, kubota dealer don't either. I will keep looking.
3 original cubs
1512 diesel
Ingersoll 3012
John deere 855
Old 09-24-2014, 10:24 PM
PGHsteelworker's Avatar
PGHsteelworker PGHsteelworker is offline
Tacosteelerman, I bought a compression tester from harbor freight for $30 dollars. It was item number 93644 and worked great on my 1782 with the D640 motor. By the way, if you take the exhaust manifold off you can see if all cylinders are getting fuel by the puffs of smoke coming out. If it sat outside also check to see if the muffler could be plugged with rust inside.
Old 09-24-2014, 10:29 PM
Tacosteelerman, by the way I live in Leechburg. If you are not too far away you can borrow mine if you want.
