Old 02-21-2015, 08:36 PM
BassBlaster BassBlaster is offline
I got it running!! Turns out I didn't have a carb issue at all. I had an ignition problem. I noticed after turning the key on and off a few times, the shut off solenoid would stop clicking. I started looking for a wiring issue and when I bumped the wires to the ignition switch, I heard an arc. I pulled the connector and all the wires were really loose. I got them all pushed back in there real good so they are not arcing anymore and it fired right up and ran beautifully.
At some point, Im going to have to replace all the wiring. Hopefully someone starts making a harness for these soon. I as told if I pulled my harness someone could use it as a template to make a new one but its so chopped up, I think it would be a useless template.
Anyhow, shes running great again and I was able to plow my driveway. First time Ive gotten to work this machine and its a beast. Im completely amazed at how much snow this tractor will push and it does it with ease. Definitely got to get my new tires mounted up soon. The front end pushes all over the place with a full blade of snow.
On a positive note, I don't think there is another 1864 in the world with a fuel system as clean as mine! The carb was cleaned 4 times today, lol.
1994 Cub Cadet 1864
1997 Cub Cadet 2165
Old 02-21-2015, 08:52 PM
Glad you got it going. MTD should be ashamed for what they call a wiring harness. Pretty much every Cyclops I work on I just take the harness and toss it, way too many connections and way too many things to go wrong, then I just make my own. Again glad you got it running.
Old 02-21-2015, 09:05 PM
Yeah I may have to wind up doing that since no one makes a harness.
Thanks again for your help. if I hadn't started playing around with that solenoid, I never would have found the wiring problem.
1994 Cub Cadet 1864
1997 Cub Cadet 2165
Old 02-22-2015, 04:16 AM
Cannon51's Avatar
Cannon51 Cannon51 is offline
Chasing wiring problems has been an ongoing issue with my 1863 and now the 1641. Do you make your new harnesses off a diagram or just know what you want to do? My 1641 is a mess of twisted together wires from the PO disabling all the safeties. I'm sure forum rules wouldn't allow you to post the diagram even if you have one or add "rewiring" to your "Cyclops Repairs" in the tech section.
Cannon
Old 02-22-2015, 05:23 AM
My 1864 is the same way. Every safety has been bypassed. The wires to all the lights have been clipped and I have a fairly large connector hanging under the dash that dosnt have a place to plug into to. Cant for the life of me figure out what its suppose to do or where it goes.
1994 Cub Cadet 1864
1997 Cub Cadet 2165
Old 02-22-2015, 09:59 AM
Cannon
Guys
I can't post what I do to my own stuff. About all I can say is that I start with the factory wiring diagram and then I decide what I don't want or need. Then I draw it up. Then it's time to start running wire.
Old 02-22-2015, 10:21 AM
Guys
What a sad world we live in, that a person can't print what they have made/done without fear of legal repercussions because of unscrupulous lawyers & idiot Judges.
Sorry for the short rant
Old 02-22-2015, 10:22 AM
CubDieselFan's Avatar
A few days ago there was a 1864 harness on evil-bay. It was not cheap, but may save a lot trouble for you.
Old 02-22-2015, 10:42 AM
I don't think replacing what I have with another stock harness will really be the best option. Thanks for the heads up though.
1994 Cub Cadet 1864
1997 Cub Cadet 2165
Old 02-22-2015, 11:33 AM
Cannon51's Avatar
I agree. I would rather start with something simpler and add the wanted accessories. As an example, this is a "Typical 16 amp Regulated Wiring Diagram" published by Briggs. Unless I'm mistaken that's what 1641 vanguards have.
Sam if you consider this post over the line please remove it.
Cannon
