Old 02-18-2016, 08:19 PM
V30crewcab V30crewcab is offline
painted the diff gloss black, not sure if that was a good idea or not. seems too shiny. its on the way back together though.
gotta put the axles back in and the rear cover and then I can fill it and try it.
I hope it works, I'm going to pickup a vanguard 16 motor in the morning for it, not that it needs a motor just want another cub with that motor. Then maybe some tru-powers, etc.
I plan on getting the motor, driveshaft, and motor plate. maybe the throttle and choke cable as well. hopefully I won't need much else for it.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 02-18-2016, 08:24 PM
Dirty Steve's Avatar
Excellent work saving that case. Great job!
Old 02-18-2016, 10:06 PM
Well I went back out and got it together enough to try it, it now works!
Just gotta do alot more cleaning and get it all back together and adjusted.
72 scout
IH 404 tractor
Old 02-19-2016, 12:03 AM
Good to hear all your hard work has paid off
Old 02-19-2016, 09:16 AM
CubDieselFan's Avatar
You are doing a great job. Keep the pictures coming.
Old 02-19-2016, 10:59 AM
Well its milled and drilled. cleaned it up in my wash tank, but I think I will take it and wash it better in my buddies steam tank in the morning if it will fit in it. then it will be ready to put back together.
I ordered new axle seals, but it appears they are wrong. according to partstree, it takes the same seal as my 1782, but this rear has the small axle tubes like an 1811, so not sure if it has the wrong rear diff in it or if partstree is wrong. guess I'll change the seals another time.
Did you drill the oil return holes in the tranny case while you had it apart?
My guess is that the rear was replaced at some point in it's life with a rear from an earlier machine. It should have the large tubes for the axles. No big deal you'll just need seals from something like a 1872.
Old 02-19-2016, 07:06 PM
Yes I did drill the case for the drains, as well as a vent tube. that far in might as well! I did get ahead of myself a little and didn't install any braces yet, but I have a mod for them in my head that I haven't had time to do yet, and I wanted to make sure it was all working before today's trip.
I just got back from a 3hr one way trip, and even longer trip on the way back due to traffic and being friday, but it was worth it.
I picked up a 1641 motor, driveshaft, shrouds, and also the hydro valve and cylinder for a spare. The only thing I didn't get that I probably should have was the wiring harness and batt cables. Will I need to modify the 1862 harness much to install it? I'm figuring its mostly just different length kinda mods, but if its something else, let me know.
There wasn't a pto on it, so I guess I'll need to hunt up one of those bushings everyone has been using for their swaps. Is that something engine warehouse will sell separately, or do I need to machine one?
I'm not in a hurry to install this motor, just been looking for one awhile. I plan on getting it all running and bugs worked out of everything else and then swap it at a later time.
72 scout
IH 404 tractor
Old 02-19-2016, 07:21 PM
Nice grab on the engine and parts. Keep up the good work.
