Old 01-01-2016, 03:54 PM
yeeter yeeter is offline
shiney.....
Old 01-01-2016, 04:20 PM
twoton twoton is offline
Nice!, What are you spraying?
Old 01-01-2016, 04:37 PM
OldSkull's Avatar
OldSkull OldSkull is offline
Look too shiney to be spray can! Unless my eyes play me
Well done Yeeter.
Gilles.
1963 100 (red)/in storage
Old 01-01-2016, 04:46 PM
bocephus1991's Avatar
Hope you have better luck than I did getting them back on the rim without scratching them to death! I scratched the crap out of mine. Next time I'll paint the insides the mount them and finish painting them after I mount them.
Brian
Old 01-01-2016, 05:00 PM
This stuff. Its been decades since I did any automotive painting, and everything has changed. So I went with the NAPA since there is one local to me. It seems expensive (to me... I think $50/qt? if I remember right, I bought it a couple summers ago). Everything on the tractor got this paint or powder coat. Most of the tractor got a 'one part epoxy primer' (oxymoron I know, its 901 grey from NAPA, maybe a fleet primer). But I was out of this so a 2k primer with activator was used on these rims.
I use a small HVLP gun for these smaller items, and a full size HVLP for the larger panels and such.
Im not sure what to think. I was used to older style Dupont paints and regular spray gun. I think I still like the regular gun although there is more overspray to be sure.
This paint is Urethane with a hardener. It seems hard enough. A little thin (so multiple coats - another thing my HVLP doesnt handle well is thick paint (like primer) - the full size gun has a larger nozzle and does a little better). Seems to chip easily if the edges dinged. By no means am I an expert.
For these rims I recon they will get buggered up mounting the tires, so some touch up after mounted will be in order (always tricky to get a tired mounted without edge dings). We will see... Those V61 6 plys are the really tough ones, still have the fronts to do.
Old 01-01-2016, 05:01 PM
I like em'
Nice work!
Up to 534 and counting...
Old 01-01-2016, 05:03 PM
Yes. A three step process. Paint. Mount. Paint again.
Maybe if I get lucky I cant touch up the edges with a small artist paint brush and not need to spray... (an optimist)
Old 01-01-2016, 05:10 PM
http://www.onlycubcadets.net/forum/s...&postcount=174
http://www.amazon.com/dp/B0002SQYV4/...1W8P2EKG&psc=1
Old 01-01-2016, 11:26 PM
ccguy's Avatar
ccguy ccguy is offline
yeeter:
With the way you are finishing everything off so nicely, I'm tempted to go the route of an HVLP gun and leave the rattle cans behind (although I love the quality of Valspar Farm Equipment Enamel). What brand of spray gun are you using?
INTERNATIONAL HARVESTER
- A Great Farm Heritage Comes Home.
1811/682/782/1440/IH #4/IH QA 42"
Old 01-02-2016, 12:46 AM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
I always lay a piece of carpet down and mount mine from the backside... that way if you scratch it it will be on the inside.. also like twoton said, use a rubber lubricant..
An automotive rim clamp type machine will also mount them without ever touching the rim..
They look nice!!
Jay
Proud owner of the following:
