#71
![]() Quote:
I wanted the gloss black and the header paints (1,100 deg) were all a matte finish. |
#72
looks good
#73
![]() Quote:
That muffler gets way hotter than 550°..... it's gonna burn off. |
#74
X2, I used it on the heat shields on mine and it's been fine, but I used header paint on the exhaust itself.
149 with kwik-way loader,1772,two 1782 super smokers, 982 SGT w 54" haban blade,60" haban deck, 50in deck cat 0 3 point, brinly cat 0: blade, plow(3), disc.123,hydro lift. 61"O" Brinly single row planter,brinly cultivator,#2 trailer,brinly 10 inch plow,3 42 inch blades,Model #1 Tiller with extenstions,haban sickle mo. 106w/ags and hydro lift. ![]() |
#75
On a diesel? I knew it would get that hot on a gasser, but I thought the diesel would be cooler? Well, if it does, I'll do it again.
I installed the replacement ignition switch (again). That seems to be working correctly and as a bonus the glow plug light works again? Rebuilt the throttle lever assembly, added a few .005 washers to tighten it up and replaced the broken spring washer. It is working while sitting in the shop, time will tell. Put the muffler assembly back on. Installed the yellow suicide knob. Pulled the grill out, can that thing be welded? I can't tell if it's cast aluminum or some pot metal. It's broken in a few spots. If I can have it welded, I can save it. And was very suprised to see that the hubcaps from the 782 fit on it! ![]() ![]() |
#76
Yep.. it looks nice and will probably work great on the heat shield... but im sure the muffler itself will probably get closer to double the temp that the paint is rated for.. Maybe go back and do the muffler with 1200 to 1500 degree stuff and leave the heat shield glossy black with the 550 rated paint
Looks great though!! A+ for the efforts!! ![]()
Jay 40 years of Using and playing with IH Cub Cadets! Proud owner of the following: Cub Farmall, Super A Farmall, Original, (2)70's, 72, 100, 102, 123, 105, 125, 127, 108, 128, 1450, (3)782's, Yellow 982, 1782, "Sam's" 2182, M Farmall and a #7 trailer |
#77
![]() Quote:
![]() Under load, on that engine, I'd say exhaust temps run in the 750-900° range. Big diesels under load will run 1000°-1100°. I don't like to see them get to 1100° and stay there though.... pistons begin to melt at 1200°. 950°-1050° is about optimum under load. ![]() |
#78
![]() Quote:
![]() ![]() Maybe I'll just send it out to be ceramic coated and be done with it. ![]() |
#79
![]() Quote:
#80
Spent 45 minutes mulching up leaves yesterday. Throttle control still does not want to stay in the full throttle position, it creeps back. I will pull it back apart and add .010" washer in the pivot assembly, hope that tightens it up enough to stay put.
The drive shaft needs to be updated. That clutch knocking is getting on my nerves and it seems to vibrate more than I am comfortable with. I need to source a 1863 or 1864 CV drive shaft, then get with Jeff in PA for the adapters. (thanks Sam Mac for the PMs) |
