Old 03-06-2017, 11:17 PM
Originally Posted by john hall View Post
How much watery goo was in the axle housings when you pulled them? My 1811 was pretty icky (couldn't think of a more technical term). Are you going to drill return holes for the rear?
They weren't bad John, I was surprised myself...
I really don't know if I am or not. Been fine for all these years.
Todd:
Factory numbers for an 1811 are:
146-782-100
147-660-100
148-660-100
149-660-100
It would be an 1811!
We need to I gots some ????
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Todd,
Looks like you have been hard at it!
For sure one of the better cork gaskets I have ever seen..
Keep up the good work!
Jay
Proud owner of the following:
Old 03-06-2017, 11:36 PM
You know the number! I'm up!!
Old 03-07-2017, 04:21 AM
Dirty Steve's Avatar
Gonna be real nice when you are done, Todd.
Old 03-07-2017, 11:09 PM
Originally Posted by jaynjeep View Post
Todd,
Thanks Jay. Yeah, it don't look bad, but always good to replace when they are this far. I think the leaks were multiple.
Have to be during the day, when I'm up to write things down.
I don't know about that Steve, but it'll work, and hopefully without leaking.
Old 03-11-2017, 09:05 PM
Been doing a little on and off. Seems like more off than on. But working on two tractors at a time is one to many for me. The 782 is now finished, so it's full on 1811 till it's "finished"...
Pump cleaned up for the new cork gasket. Diff ready for the pump and gasket. Gasket applied to the pump, and installed. Thanks Jon.
New axle seals, and gaskets installed, trunnion repaired. Needed to fix a couple grooves in the "swash plate". Welded the corners and filed them square again.
Those "pins" you see sticking out of the diff where the axle tubes attach are just a couple 3/8 bolts with the heads cut off that I use for guide pins while mounting tubes, easier with one had than trying to hold everything and not goobering up the gasket.
Built a "cross over" patch between the two front mounts. The one on the right was broken off, but the left was good. So I welded a cross brace from mount to mount and bolted it to the bottom of the diff. I understand I don't need the front mounts when using the braces, but still wanted to attach them to the frame, regardless if I'm using braces or not. Piece of mind, in my "mind" anyway.
Old 03-11-2017, 10:10 PM
jaynjeep's Avatar
Top notch work Todd!!! Looks like you are quickly becoming an expert on re sealing these rears!! I got one tore down and can't seem to find the time to put it back together... maybe I should send it your way!?
All looking awesome as always!!
Jay
Old 03-11-2017, 10:15 PM
V30crewcab V30crewcab is offline
I don't see any drain holes drilled in the case!
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 03-11-2017, 11:33 PM
Thanks Jay. "Expert", I'll never be, know enough to just get by. Plus with a little help from my OCC buddies.
Thanks for the offer, but I wouldn't want to take all the fun away from you. Oh, and good talking with you the other night.
I don't recall saying I was going to...
Old 03-11-2017, 11:58 PM
jaynjeep's Avatar
Likewise Todd!! We shall do it again soon!
Jay
