Old 12-28-2017, 09:08 PM
Marko141's Avatar
Marko141 Marko141 is offline
Kinda hoping for some snow this week here in NY, wanting to use that snow blower!
Cub Cadet 127, 1450, read bottom plow, blower, tiller, wheel weights, chains
Old 12-28-2017, 11:23 PM
Yep! What Sawdust said.
It's a simple system so start with the steering wheel and see where the movement isn't when you begin to turn it. Start with the steering box and work towards the wheel.
The tie rod ends are consumable (these are about 40-50 yrs old now) and are easy to replace and available cheaply.
Isn't that what I said??
Old 12-28-2017, 11:48 PM
Thought I read that before...
Old 12-29-2017, 07:39 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Careful what you ask for!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 12-29-2017, 07:41 AM
jbrewer's Avatar
I've edited my post to include you.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 12-29-2017, 10:52 AM
Marko141's Avatar
Talking
It's looking like we might just get some snow this week
Old 12-31-2017, 04:14 PM
Marko141's Avatar
So it has been down into the negatives here in NY, and today I decided I want to start the tractor and blow some snow. Well I have a battery saver hooked up to the battery because it's been so cold and it rolls over fine. But when I pull the choke it starts to run, then it cuts out bringing everything to a stand still. It stops rolling over and what not. So I'm curious as to what my issue is. Ik the starter isn't as strong as it once was but... I don't want to take it off and rebuild the starter until the summer when I do the rest of the tractor. Is there anything else you guys could think of? Maybe it's just way to cold, only 4 degrees outside as of now.
Old 12-31-2017, 04:37 PM
jbrewer's Avatar
Sounds like a combination of weak battery and cold temps.
Do you have jumper cables? If so, jump it from a car, start with choke and let it warm up as you roll back the choke...
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 12-31-2017, 04:52 PM
Gompers Gompers is offline
Mine does that when it’s super cold out too. Needs a bigger battery. I hook up my battery starter to it and it’ll crank it over fast enough to get it going. I’m betting a magnetic block heater on the hydro case would go a long way to letting it spin faster without a new battery. Having to turn that hydro pump with cold thick hydro fluid is probably the cause more than the cold engine oil, especially since those K series engines are just splash lubricated.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240
Old 12-31-2017, 06:12 PM
Marko141's Avatar
Magnetic block heater would be a great idea, it has just been so cold here.
