Old 12-28-2018, 03:33 PM
IHCubCadet147's Avatar
They're all painted!
Old 12-28-2018, 04:47 PM
AndrewNoyes AndrewNoyes is offline
Looking good! Can hardly wait to see the end result!
Old 12-28-2018, 06:38 PM
Bamafan Bamafan is offline
Inactive Member
Looking good!
[B]Larry[/B]
Old 12-28-2018, 06:45 PM
The good...
Looks good when is assembly time?.
The bad...
I cannot tell, but are the brake rotors masked off?
The other concern is the breather for the tranny, was that covered also?
Up to 534 and counting...
Old 12-28-2018, 07:42 PM
Thanks for the compliments!
Lew, I'm hoping to start reassembly next week. The brake rotors were not masked off, but the breather was.
Old 12-29-2018, 09:37 PM
ColoradoCadet's Avatar
ColoradoCadet ColoradoCadet is offline
I am starting on my 149 rework and was wondering if you replaced the rear axle seals? If so I was hoping you could tell me where you got them and what size they are? Something appears to be leaking back there on my little gem. ;-) Thanks.
Wayne
Old 12-30-2018, 07:43 AM
I did not replace them, I don't think they were leaking on mine. I did replace the cork gasket though.
Old 12-30-2018, 09:20 AM
IHinIN IHinIN is offline
Chances are it’s the relief valves and/or the cork gasket that are leaking. They are much more prone to leaking than the axle seals.
Old 12-30-2018, 12:48 PM
wagonmaster wagonmaster is offline
Ware is this leaking cork gasket I keep hearing about ?
Old 12-30-2018, 01:17 PM
john hall's Avatar
Between the pump and the transmission there is about a 3" dia cork gasket. Its a very cheap fix, but takes a good amount of labor. Search the forums you should find multiple references to it. Given the age of the machines, when You go in to do this $10 repaair, you can drop another $1-200 or even more in other needed things that you take apart in the process.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
