Old 10-08-2019, 09:34 AM
Dueling wheels.….
This ought to be interesting!!
Old 10-13-2019, 11:43 AM
Cub70's Avatar
Cub70 Cub70 is offline
Default Dually Adapter Part Numbers
Had a request for the part numbers for the dually adapters, end plates, and lug nut/lug bolt set. These dually adapters are made for different rim/tire combinations, so that being said, the following parts number are for the “6-12” rim/tire setup ONLY. These are the 7” option.
These are purchased through www.extrememotorworks.com.
• CC-01-001-700W (round 7” dually adapters 2 are included)
• CC-01-050 (round cover end plates 2 are included)
• CC-01-048 (Cub wheel stud/nuts 10 are included)
I hope this helps!
1964 Cub Cadet 70 (Full Restoration), Upgraded/Rebuilt K181 8hp engine, custom exhaust stack/flapper, NEW clutch, brand NEW steering column, Custom made wiring harness w/ammeter, LED headlights and tail light, Custom 2” receiver hitch, Custom pull behind paint matched trailer
Old 10-16-2019, 05:26 PM
Cub70's Avatar
Default Dually Wheels are Installed
Finally got the dually wheels installed today! I also added valve stem extenders from the inner tires to one of the wheel weight holes so I can check both pressures from the outside wheel. One picture shows the stainless steel braided valve stem extender and a second picture of the outer rim face shows the two “Cub Cadet” valve stem caps.
Old 10-16-2019, 05:27 PM
Cub70's Avatar
More pictures
Old 10-16-2019, 05:28 PM
Cub70's Avatar
More pictures
Old 10-16-2019, 05:30 PM
Cub70's Avatar
Final engine Pictures:
Old 10-16-2019, 09:35 PM
IHCubCadet147's Avatar
The duals look great, nice work!
Old 10-16-2019, 10:00 PM
Cub70's Avatar
Thank you very much for the compliment! I like the way it looks too
Old 10-16-2019, 10:14 PM
Cub70's Avatar
Before & After
Old 10-17-2019, 06:21 AM
twoton twoton is offline
Duals and a stack, looks great!
