#71
Closer and closer and cleaner...
#72
Back to where I was before the engine tune debacle, I tested the "return to neutral when you step on the brake" function (I adjusted the brakes first. Wow! Real brakes!)
With the rear wheels up on jack stands: From REVERSE, it returns to neutral every time From FORWARD it doesn't return to neutral. Hope there's enough adjustment in the linkage to compensate. Then I can button things up and use this thing.
#73
Well, the answer to this is "no".
![]() No matter how I adjust the brakes and the hydro arm , there doesn't seem to be any noticeable change in the position the hydro returns to after full application of the brake. This is not good. Applying the brake while the hydro is in reverse does return the hydro to the Neutral position, but that doesn't happen when the hydro is placed in the Forward position. There's also a condition I've seen on two 123's , where the brake pedal , if not adjusted so that it's pretty sensitive to pedal pressure seems to go so far to the "floor" that the spring won't return it nor is it easy for the hydro arm to return to neutral. It's not the condition you want when it's time to stop. There's a "click" feel as if it's gone over center somewhere but I can't see it when I'm contemplating things lying under the tractor. (UPDATE: I see where that "over center" feeling comes from. When the pin on the hydro handle mechanism clears the bevel on the ramp part of the complicated hydro control mechanism WAAAAY up there in the dash tower, I see why the pedal sticks and doesn't return. My guess is, that the brake action should never cause the pin to ride over the edge of the beveled part. Maybe...) There does seem to be 50 yrs of slop in hydro control shaft to the hydro control plate that might not be helpful. ![]() Anyone seen such things on other tractors?
#74
I don't use the pedal at all. Just move the lever to stop the tractor.
You don't need to try to apply the brakes to stop the tractor,when the lever is moved to the no-go position, you WILL stop.
Cub Cadet 100 "Super" (red) show tractor Cub Cadet 100 show tractor. Cub Cadet 100 worker Cub Cadet 106 refurbished/modified (red/white) Cub Cadet 128 "refurbished" Cub Cadet 1450 my dedicated mowing tractor Tractors awaiting refurbishment:100 with fenders,128,73 with creeper and fenders,106,122,147,126 with creeper. 100 w/pan seat and 3 point hitch |
#75
In other words, it is not the brakes that stop the tractor, it is the fact that the hydro is returned to the neutral position that stops the tractor.
#76
Hi Tim,
Yep, since the brake puck on this one was frozen, I used it brakeless for years. Since I was tearing into it (and since I wanted to learn how the tractor splitting process went) I tried to fix it "right". More on this later. It would seem though that using the hydro to stop the tractor (in a mowing situation where stopping and starting is frequent) would wear out the trunion or the driveshaft as all the start/stop load is on those little pins. In my case, it wallowed out the driveshaft and I got a new one from Jeff (very nice by the way!). Maybe it's a worry about nothing but I'd like the brake to work. Now..... The brake puck, freed from its bore worked for while when reinstalled with a new o ring and the bore cleaned up a bit . Now, however, after having gone though a few hours of trying to get the brake action to return the hydro lever to neutral, the brake puck is now adjusted all the way in and there's no braking action (there used to be). I'm not sure what I could have ruined but I was able to get the brake arm out (without splitting the tractor) , and the brake puck backed out of the bore (oh look! Hytran everywhere !) briefly. the ball was still in there, and the brake rod itself was ok, but again upon reassembly I run out of adjustment without gaining any braking action. I broke the brake somehow ....?
#77
![]() '70 107 with k301 engine swap '71 106 with 38" deck '70 147R with factory replacement k321, 42" deck '61 Original with 38" timed deck '63 70 "pinkie" 1863 with 54" deck '46 Farmall H, '50 Farmall Cub 105 x2 (parts) |
#78
Did some more work today. Replaced points and condenser and in doing so removed the last of the misfiring. It really seems to run well now.
I noticed when I was activating the PTO clutch, that the head of the clutch was grinding shiny flakes off my new brass PTO when it was pressed against it. Sigh.... I guess I'll need to remove the grill again and polish the surface that the button rubs against with some fine sandpaper
#79
Make sure the PTO is adjusted properly. It should stop spinning fairly quickly after disengagement. Maybe it’s staying partially engaged.
Doug Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift 1250 w/hydraulic lift, lights,weights, spring assist. 50C deck converted to an A with front wheels 44C deck converted to an A with front wheels. QA-36A 42" blade |
#80
Short of disassembly/ removal are there any tips to get it to disengage (activating arm w/button is correctly engaged) One more thing!
