Old 01-24-2010, 06:48 PM
CBH's Avatar
CBH CBH is offline
I guess the joke's on me! I didn't think that you'd have snow pics!
The 100 looks kind of naked without the back rest on the seat! I didn't realize how much it added to the looks until just now!
Old 01-24-2010, 10:32 PM
I totally agree, CBH. It's amazing how the backrest made the 100 look much better.
Old 01-25-2010, 11:20 AM
dleblossom dleblossom is offline
Originally Posted by jeff k. View Post
Thatz so cool when they help,my 3 soon to b 4 yearold loves getten in there n gettin dirty. his mom isn't as fond of the idea when it comes time to get cleaned up.:biggrin2.gif: Is that a 1415 in th e back round,how do u like it ? I just bought one last fall . going threw it now so it s ready for spring.
you are correct sir that is a 1415 i just bought it off of a local repo website took me a month but i have all the bugs worked out mostly electrical problems. now everything is back to the way it should be. i have both wire diagrams for the tractor and engine also the owners manual and the service manual all in pdf format if you would like them let me know and ill email them to you
Old 01-25-2010, 10:12 PM
jeff k.'s Avatar
jeff k. jeff k. is offline
Cool
I had a little type o mine is a 1315. they look very similer. I got the motor and chassis service manules shortly after i brought it home. it looks pretty good for a 20 year old machine ,but it defenitly got it's fair share of work by the looks of the mower deck i just took off. 3 of the 4 haning brackets have been replaced with home made ones. A little lovve and some new parts n she 'll b like brand new
cub cadets : orignal w/ mower,orignal w/ push blade, orignal w/BB-36 snow thrower,72w/creeper,100, spirit of 76,76,55, 95 Electric,107,2-125 ,Johnson TC-10 loader, ,127,149,1100,282,382 hydro,382,482,2-IH 582,682 w/ spring blade,2-782,782D,1282,982,1782 super, and ,2-custom built 582 puller,2-narrow frame pullers,and 1-stock 582 puller
Old 01-26-2010, 12:59 PM
Today the paint was dry on my weight bracket,
so I put it back on and added the 3 little weights.
I won't know if #300 is enough till it snows
Old 01-26-2010, 01:15 PM
CBH's Avatar
CBH CBH is offline
That's a lot of weight!
You need to put a toilet seat on it, just to top it off! That would look funny! :biggrin2.gif:
Old 01-26-2010, 01:24 PM
Wow! I hope you've got that very securely attached to the frame and rearend in a lot of places...that's A LOT of weight hanging quite a ways out with no bracing. I hope nothing breaks.
Old 01-26-2010, 02:48 PM
Nice weight bracket, ol'George!
Got some seat time today. Had a lot of limbs to pick up, after the storm we had Sunday night. I forgot to take a pic with the cart full, so I got an after pic. There were some gumballs in the cart though!
Old 01-26-2010, 04:03 PM
The fabricated bracket attached to the tractor is angle iron,
being 2 pieces of 3/8 thickness, 4"x6"x 10" long.
They are welded together to make a "C" shape which snugly slips on either side of the tractor frame.
It attaches to the frame with the existing 3/8" bolt holes on the frame sides, below the sleeve hitch piviot, it also attaches to the lower sleeve hitch "U" brackets 1/2" holes on the Differential housing
That gives me 4, 3/8" bolts and 2, 1/2" bolts in a shear configeration.
Welded to that, and protruding out 24" is a 1/4" thick 4"x8" piece of truck frame,that the weights sit on.
The fabrication is brutally strong and it ties the dif. casting & tractor Frame together.
As I see the leverage effect, the weight is pulling the frame rearward & downward and pushing the diff.casting foreward.
Without the QA42 attached I'd say there is maybe #100 +_ on the front axle.
Old 01-26-2010, 04:12 PM
dieselsnowmobile's Avatar
dieselsnowmobile dieselsnowmobile is offline
ol'George, considering that you are using a blower, that should be plenty of weight. The drive tires do not have to work as hard as pushing snow.
I have a 200 lb concrete weight hanging off the back of my Cub as well (although not as pretty), and it works pretty good. Between washer fluid filled tires and chains, it pushes snow pretty good. I pulled my wife and daughter on a sled in about 10 inches of snow in the yard, and it would slip a little, but never spin out.
CC 104
