Old 05-24-2014, 08:51 PM
Nice tractor Nik!
I picked up another pair of weights this morning. Then went and got a sweeper. The bag is new and the rest barely looks used either. It works really well, I just need to add a rope for easy emptying. Adjusted the carb and changed the oil on the 102, then put it to work!Got a little mowing done too. A lot more for tomorrow, plus a cookout
Hope everyone enjoys the holiday!
Nice finds, Travis!
Old 05-24-2014, 08:53 PM
Sorry to hear Allen! Let us know what you find out.
Thanks Mike! I believe it's from the oil filter lines leaking, and the engine blowing the oil around.
Old 05-24-2014, 10:29 PM
Nice pickups on the weights and sweeper Travis!
Old 05-24-2014, 10:30 PM
Ok, that's not to bad of a fix then Allen.
Old 05-25-2014, 01:13 AM
jmwolf jmwolf is offline
Spent most of the day on a tractor. Mowed with the 1862. Then went to the mess I have in the backyard. I'm in the process of putting in some drainage pipes. I dug the trenches earlier in the week, so today I started laying the pipe. I'm doing about 2" of stone, then 4" pipe, then cover the pipe with stone and ground on top. Homemade bucket on the front and brinly box blade on the back sure does help.
(I'm not sure why the picture is sideways or how to change it, I'm a little new here.) (fixed it for you)
Justin
1641 with 3 pt and front hydro ports
1862 with bagger
54" power angle blade
451 snowblower
Old 05-25-2014, 07:27 AM
Cool pic of the cub in action!
Old 05-25-2014, 10:55 AM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Default Fire!!!
I almost burnt the 1864 up! I was 40 minutes into mowing the Xmas trees this morning and started to smell something. About 5 seconds later smoke came rolling out the front. I immediately shut it down and pulled the side panels. I didn't see any oil or signs of the source. I fired it back up and the smoke was flying again. It was coming from around the left spark plug. Pulled the wire off and could see some oily grass build up smoldering. I spit on it and blew out what I could. Waited 10 minutes and fired it back up, no smoke. Immediately drove to the shed and blew everything out with the air hose. I guess I have been slacking on my clean up. I think I will be pulling the side panels after every mow now! I also spotted a missing nut on the exhaust manifold right in front of where the fire started. I an a little embarrassed and almost didn't post this but I thought it is a good lesson. If it can happen to my OCD a$$, it could happen to anyone.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 05-25-2014, 11:51 AM
cub123's Avatar
cub123 cub123 is offline
I finally got the 149 put back together after having the rear out for the last 6 months to remove a broken bolt, lol. Nice solid tractor, now to clean up the loader and swap it from the cobbled together 12 horse 149
Old 05-25-2014, 09:18 PM
149 looks good all cleaned up
Old 05-26-2014, 07:54 AM
149 looks good Ben!
